AFM Delete and California Smog
Geotrash
Dave
Richmond, VA
And even if it is tip top they try to find something to charge you extra for in my experience.
My shop has been honest because they know I'm a DIY-er, but they always do offer to do something that they know I won't feel like doing myself, like a brake fluid flush. About half the time I take them up on it.
Marky Dissod
The smog test in and of itself canNOT test for the presence or absence of V4 mode behavior.
If your accumulated exhaust gases limbo underneath all 3 bars, congratulations.
If not, address your mechanical concerns, or get tuned, or whatever combination.
The test that connects the gubbamint compuduhr to the powertrain control modules canNOT use HPTuna or EFItsalive or any other analysis software to detect if any modules have been tuned.
That test can ONLY verify checksums & checksum verification numbers (basically a checksum of a checksum using multiplication and/or division in addition to addition & subtraction).
Otherwise the gubbamint would simply examine the main spark table or the normal mode shift table to see if either was changed (THE two MOST IMPORTANT tables to tune).
The gubbamint can only check checksums, checksum verification numbers, and exhaust gases.
Proof:
How'd the European gubbamint catch VW group diesels in the act?
They used portable exhaust gas analysers in the trunk.
They did not use the Deutsch equivalent of tuning software to examine or compare the tune with anything or anything else.
I will continue to remain mystified as to why more of you are not yet tuned ...
Dustin Jackson
Dustin Jackson
@Marky Dissod I don't even think they checked for that, they took my Tahoe back for 5 minutes and then I was done, I think they JUST check the emission monitors. I am curious if I could gut my cats and still pass smog as long as I did it without raising suspicion and keeping my emission monitors looking properly and o2 sensors addressed. but that test will be for a different season lol
Marky Dissod
... don't even think they checked for that, they took my Tahoe back for 5 minutes and then I was done, I think they JUST check the emission monitors.
You're likely right. I'm just trying to give all these other people who are on one fence or another about getting tuned one more reason to get tuned.
I am curious if I could gut my cats and still pass smog as long as I did it without raising suspicion and keeping my emission monitors looking properly and o2 sensors addressed. but that test will be for a different season.
So far as I know, safest way to get away with this
IFF one were so inclined!
would be to:
open the catalytic converters like clamshells
close the clamshells AFTER installing export pipes - instead of catalytic material, the shell contains a pipe now
(in countries that have no catalytic converter requirement, they use export pipes instead; good luck finding THOSE parts numbers anonymously)
properly installing / re-installing pre-cat O2 sensors & post-cat O2 sensors
deactivating post-car O2 sensors & codes with a proper tune
That same 'proper tune' must also IMPROVE power AND MpG at the same time.
By which I mean: the tune must effectively perform the same function as the catalytic converters.
Those who take emissions sniffer tests with E85 in the tank should have a MUCH easier time passing ...
Once we think of a better source than corn, E85 may NEED to displace gasoline to improve emissions ...
Dustin Jackson
Dustin Jackson
I've heard of people hammering the cats out with a spike and leaving the outside completely unscathed which would be the way I would try and do it and maybe add another muffler to keep it stealthy
Marky Dissod
... hammering the cats out with a spike and leaving the outside completely unscathed ...
A single tap with a knuckle, a hammer / mallet, etc, acoustically gives this away.
Also, hollowing out cats causes pressure wave disturbances which more often than not messes with the engine's power curve.
Catalytic converters are what they are because they have something inside them.
Better to replace the platinum / palladium / rhenuim / rhodium with export pipes.
j91z28d1
I always hate the smell of a car with the cats deleted. It gets in my clothes and lingers. I’ve owned a few and I’ll keep the cats for that reason alone.
when I got my motorcycle back in 06 it was of the first to have a cat, and of course everyone puts an aftermarket exhaust on, saves weight and looks cleaner. I tossed mine in with the loan and put it on by the 2nd ride. few years later I gave up, couldn't take always smelling like gas fumes. put the cats back on it.
I don't know what it is about this yukon but man you can smell the outside world. Recirculation helps a bit, but I can still smell a ford truck either no cats or just mod motor miss 10 cars ahead of me. non of my other cars do I notice it like this thing. once it's in the cabin, it's hard to get out too.
Thanks for the input everyone, good to get different perspective and opinions.
When the time comes I'll just go to my normal smog guy and see what happens, I think he's a safe spot to test this at.
I guess the fear mongering of the auto shop guy from yesterday spooked me a bit but his information doesn't exactly align with what I've found in my own experience and research.
Quick side note - Jasper engines does make a CARB certified AFM deleted motor for these but that's not relevant.
Those guys were full of it, if worse comes to worse you buy a used unmarried canned carb certified tuner, hypertech, etc and put that on it to pass smog and then put the bb tune back on. I did it, it passed. Relax
Dustin Jackson
Dustin Jackson
@Doubeleive My coworker picked up an Avalanch with a lifter problem and so he was following in my footsteps but was hesitant since it wasn’t proven that my motor would pass smog with the AFM delete. I told him if he pays for half of the smog we can test with my Tahoe and sure enough it passed this morning just fine
adventurenali92
Big Bear Lake, ca
Interesting input from everyone so far. I’ve had my 2006 LQ4 autocal tuned via blackbear PF since late 2017 I believe, and while my engine is not to totally modified yet, I have never had an issue with passing smog even with my spectre intake setup and the magnaflow muffler in place of the OEM one. Kinda depends on where you go and whether or not they actually inspect things. Only year that happened to me was when I forgot to have it smog tested up in big bear. He inspected some things but I dont think found anything he could to fail me on. I passed as that years DMV tags and such.
I am planning some mild power upgrades and will be re tuning. As far as I’m aware all carb complaint upgrades will not raise any flags on an inspection. As long as your check engine light is not on within a couple days leading up to the test being done I shouldn’t think you’d have anything to worry about?
Edit: read that you passed fine. Excellent that it wasn’t difficult.
smwalker
What we have derived from a year of passes and fails for modified software is this. The SMOG computers seem be ignoring tunes on any GM vehicle that comes with a AFM engine. So long as the only thing your tune does is turn off the AFM system. Start messing with turning off OBD monitors and you will fail.
We have seen passes on the L77, L76 and L99 engines that have DOD / AFM tuned out.
And it is only logical why they excluded them. Imagine all the Trucks and SUV out there that have had the DOD tunes out because of the failed AFM system. They would have had a couple thousand people every year throwing up a stink on why thier SUV could not be drive in CA any longer because of GM's screwed up system.
So if you got an AFM engine for now you got a free pass. Just do not go nuts with the tunes, all monitors still have to report and complete to pass a SMOG in CA.
Geotrash
Dave
Richmond, VA
VERY helpful tidbit of knowledge. Thank you.
2006Tahoe2WD
Silicon Valley
Anyone please correct if I'm wrong. The BB solutions provide the CVN/etc. needed so that the recent (after July? 2021) CARB testing will not detect that the two files it checks are not what the factory provided. In other words it passes that part of the test.
(for 2016 5.3 Tahoe)
The more important question(s) for me are are the pros and cons to the various lifter/cam scenarios after the "software" stops allowing oil to the VLOM:
1 - keep the current used DOD and non-DOD lifters (potential issue(s) worn cam and worn DOD lifters)
2 - replace the current DOD lifters with new DOD lifters (standard lifters on the DOD lobes doesn't work well, the DOD lobes are different producing claimed error codes and/or poor runnng, this is in need of confirmation)
3 - replace cam with all standard lobes (possibly a slightly bigger cam) with all "standard" lifters (clean solution but hard to go back for CA resale)
Dustin Jackson
Dustin Jackson
In the testing that I did in this thread and with my coworker it seems that they do not check the computer pass emission monitors but this is not indicative of the SMOG process everywhere, just in the couple of smog shops that we tested in my city in California. I have heard that BB tune is done very well and shouldn't raise any flags but a dealership with warranty hours on the line would probably dig deeper into ECU tampering than a SMOG shop.
Myself and others I've seen have still encountered lifter collapsing and/or turning in the tray situations with only AFM tuned off but also there are a lot of others that have had great success just by tuning it off and leaving the AFM lifters and cam in. I would say that tuning AFM out will reduce your chances of lifter failure but to have the least chance of lifter failure I would swap the lifters, cam, and valley cover for non-AFM versions.
I don't think that you will have a problem with reselling the Tahoe after an AFM delete
Marky Dissod
2 - replace the current DOD lifters with new DOD lifters (standard lifters on the DOD lobes doesn't work well, the DOD lobes are different producing claimed error codes and/or poor running, this is in need of confirmation)
For ANY vehicle, with either version of cylinder deactivation:
After disabling cylinder deactivation in the ecm, discard the complicated lifters and replace them with simple lifters.
The older the camshaft, the more urgently the camshaft should be replaced. An old worn out camshaft on new unworn lifters is a bad idea.
May as well replace / upgrade the camshaft with a slightly better cam that does not feature cylinder deactivation.
Marky Dissod
Myself and others I've seen have still encountered lifter collapsing and/or turning in the tray situations with only AFM tuned off, but also there are a lot of others that have had great success just by tuning it off and leaving the AFM lifters and cam in.
Statistically speaking, eventually, we can all guess with fair certainty which type of lifter will tend to fail first.
Turning off cylinder deactivation will let the dual-mode lifters last longer, but given enough time, the single mode lifters will tend to outlast them.
... tuning AFM out will reduce your chances of lifter failure, but to have the least chance of lifter failure I would swap the lifters cam and valley cover for non-AFM versions.
I'd rephrase it like this:
The less cylinder deactivation, the longer the dual-mode lifters will last, because their inherent flaws are being minimized, although not completely avoided.
The design of dual-mode lifters themselves is the root of the problem, even with cylinder deactivation disabled.
The simpler lifters are of a more robust design, and will nearly always outlast the dual-mode lifters, given enough time.
I don't think that you will have a problem with reselling the Tahoe after an AFM delete.
You'd have a harder time reselling the the Tahoe without the AFM delete.
Deleting the AFM makes it MORE valuable, and makes it hold more of its value even longer.
2006Tahoe2WD
Silicon Valley
Makes sense. The Tahoe I'm looking at has 68k miles.
I wonder if the ecm can detect the slightly if any difference in the cam. I think not because I haven't seen a mention of it on the internet.
The issue I'm still thinking of is reselling in CA and I don't pass the visual or if somehow the buyer finds out. I know that's paranoid but it is a thing. I would probably opt to modify the stock VLOM to help with passing the visual.
The remaining issues are:
- cost and getting a place to make the changes (cam and lifters/etc.)
- other while-you-are-in-there (e.g. get heads cleaned up and checked)
- trans torque converter
- I think leave the big oil pump in - I don't think it hurts anything
2006Tahoe2WD
Silicon Valley
The simpler lifters are of a more robust design, and will nearly always outlast the dual-mode lifters, given enough time.You'd have a harder time reselling the the Tahoe without the AFM delete.
Thanks and yes. Better to get the dual mode lifters out of there and probably don't put new lifters to ride on an old cam.
I agree more value with DOD delete but in CA you have to pass smog or no sale.
varminpoolteam
