Want to take my 2010 Yukon XL Denali with 180,000 miles for a family trip from Michigan To Florida
B
bobby2175
Finished up the dashcam - front and rear, stopped the rattling of the front center speaker in the dash, and finally got an organizing tray for the center console. Going to move on to LED lights inside next.
One thing I'm struggling with is finding the cushions for the front seats. I can find the covers. I've tried the Seat shop, a local company that seat shop recommended, but the cushions are nowhere. These are the heated and cooled front seats. Any thoughts?
alpha_omega
Michigan
Since I wrote this reply a couple weeks ago and then never hit send, I’m a little late to the game. However, I’ll chime in on a few things to potentially help the next guy or maybe someone at random who reads through this.
The torque converter question all depends on the mileage your transmission has on it and what kind of maintenance it’s had. There’s no point in putting in a brand new TC if your trans needs rebuilt. The last thing you want to do is mess up a brand new converter. The same goes for a trans rebuild without replacing the TC, as you would then run the risk of that frag grenade wiping out a newly rebuilt transmission. I’m not even sure if a reputable shop would rebuild or warranty their work on the transmission without having replaced the torque converter.
If you have the funds available, you might as well buy the Tech2. If you’re not planning to keep the Yukon or have several other vehicles that are not products of GM, then the Autel might be the right choice. Just know that even that model doesn’t do everything the tech2 can (simple $h*t like a full system brake bleed - despite what it says…doesn’t work for our vehicles. The same goes for some key fob programming - it doesn’t work on specific models like my wife’s old car or my uncles Lexus…despite what the instructions and online info said the product could do). I was a little pissed to have spent [wasted] the money, which is why I ended up buying a genuine Tech2, full gambit with the candi, laptop and hard case. Take a look at this item - eBay item no. 186109718891
As for the oil change, I have to make a couple comments for any of the new guys who lack the Jedi abilities to pull the plug without splashing a drop of oil. First hint…do NOT pull the fill cap prior to pulling the drain plug. Hot oil moving way too fast for the rookies. Wait to pull the cap until after you’re out from under the vehicle - in a safe zone. Just be mindful of your drain pans location. Personally I have my drain pan sitting up close to the vehicle frame to prevent spillage, and I also use a splash pad inside my drain pan to keep oil from getting all over the place. The same goes for my transmission drain pan. It has an oversized splash pad/mat for the larger catch pan, and they normally sit on top of a metal drip pan (large rectangle pan, very shallow but helps with any: “areas of concern, oops’, oh $h*ts!, or by the way’s…”; all of which are sitting on a big piece of cardboard.
For those that don’t already know, or for whatever reason don’t own a funnel, you can cut the bottom out of a Mobil-1 quart and thread it onto your oil fill tube, which can then be used as a makeshift funnel. I keep it along with one and a spare quart of Mobil-1 in my Denali for just such an occasion. This may work with other brands, but I can’t say for certain as I have never used any engine oil in any of my vehicles besides Mobil-1. The trans and differentials have only ever seen ACDelco, Amsoil or Royal Purple. Other than my ‘02 which used GM’s special blue Transfer Case fluid. I’m sure someone else can chime in.
Lastly on the oil change topic. See the photo below in the event you do not already own enough tools or lack the patience to become one with your Jedi abilities. This is a flexible drain/fill plug tool that uses a neodymium (rare earth) magnet to assist in unthreading the final turns necessary to safely (and cleanly) remove the plug. Doing so without dropping it into the pan splashing oil all over yourself, your clean cardboard, the underside of your vehicle…etc, is somewhat of a learned skill.
OTC - 5911A
alpha_omega
Michigan
Im not sure how bad off your seats are or how much you’re looking to spend, but you could always try just buying two new captains front seats off eBay.
Are you doing an AFM/DoD delete through BlackBear in addition to your standard tune?
B
bobby2175
Great advice - thank you! I do plan on keeping the Yukon for a long, long time. I'm very interested in getting a tech 2 - any suggestions on where to reliably get one?
Yes, I'm doing the AFM delete and tune - did my log yesterday and sent everything over to @BlackBearPerf.
My vehicle has about 182,000 miles on it. I'm the original owner and maintenance wise, it's only had a couple of fluid flushes along the way and a filter change last week relative to the transmission.
I don't have any issues with the truck today. It runs really well and haven't noticed anything out of the ordinary with the engine or transmission. I don't do any towing and mostly highway miles.
Geotrash
Dave
Richmond, VA
Another good option for the front seat foam, is to remove it and hit it with a steamer. Some folks have even had decent results without actually removing it. It’s possible to completely rejuvenate the seat foam just by steaming it with good hot steam.
rdezs
155,000 on the Escalade and just did the starter and alternator as preventive maintenance. Tore down both just to see how far gone they were, perhaps a couple more months left on them was all. Well the starter is a tight fit with the all-wheel drive, it really does fit coming out on the passenger side just pull the tranny cooler lines over a little bit. Cheap insurance when you consider what they would charge you out of town
rdezs
I did the water pump at 130,000 as preventative maintenance. Great time to do your hoses and belts, tensioner and pulley as well as the thermostat and flush the system. Check above your oil filter for your oil leak. Probably coming off the oil cooler fitting, pretty common. Inspect your transmission cooler flexible lines in front of the engine. They're known to start leaking at the factory crimp connections. You can carefully cut off the factory crimp and you have the perfect connection for regular hoses with clamps.
alpha_omega
Michigan
I read this three times wondering what the heck a “seamer” is going to do to fix your foam, before realizing you said steamer. Creative idea!
Or better yet, use a set of AN to tube fitting adapters and you won’t have to mess with any hose clamps. -6 AN x 3/8” tube fitting (with brass ferrule). That’s if you’re replacing the old trans lines w/ braided and not a new OEM set of 3/8 inch hard lines.
B
bobby2175
Happy Thanksgiving, everyone! I really appreciate all you've done to help me learn, tinker, solve issues, and truly enjoy my truck again! Hope you all enjoy the time with your families.
So, against my better judgement and the comments from all of you, I decided to put some E85 into the truck today without new O2 sensors. I didn't fill it - I was at about 1/8 of a tank of 93 octane and put about 7 gallons of E85 in which took me to less than a half tank in total. Drove it about 25 miles or so today and it actually drove well. What would be my indication that I was stupid in doing this and should have changed out the O2 sensors first? In my head, when I get back to a quarter tank, I was going to put another 5 gallons in. What are your thoughts?
I'd say that the most likely, and probably worst result would be inaccurate alcohol content calculating leading to worse fuel economy without the full benefit of the E85. Nothing detrimental. I don't know the prices of fuels in your area. But, primarily running premium otherwise, I'd bet that your loss in MPG still doesn't outweigh the cost savings.
alpha_omega
Michigan
With a 6.2 in the Denali all I’ve ever run in her is premium. So I can’t begin to talk on the E85 topic. I run non-ethanol in my lawn equipment or a premium mix if I can’t find non-eth, but that’s about as far as my experience goes with the different grades of fuel.
donjetman
I drive conservatively and don't tow.
Our 6.2L isn't a flex-fuel vehicle.
I've run 87 octane for a yr, 89 for a yr, and 91/93 for the past 2 yrs. I even done 20-30% mix of e85 with unleaded. Runs great on them all. But I got knock message a time or 2 when running 87 & 89.
Here a data chart someone? here (not me) posted a couple of yrs ago.
B
bobby2175
Thanks for all of the info! I'm on my 2nd tank of E85 and haven't noticed any issues so far. Truck is running well. Here are my current prices.
Got my @BlackBearPerf tune files installed and WOW - what a difference! I'm up to about 120 miles or so on it so far and it's awesome!
Even with the tune, I'm still running a little rough on idle - I've noticed my idle is a little higher than before. I'm going to see how this goes with E85 for a few more tanks and then decide where to go. I may need to go to plugs and wires next even though they were replaced at the dealer about 60K miles ago. I won't touch this until the spring.
I also started replacing the lighting to LEDs. Got the inside done and moving outside now. Purchased the Diode Dynamics SS3 fog lights, but don't think I'm ready to replace the headlights to LED housings yet. I was thinking about just replacing the halogens with an LED bulb. I've been reading a lot of the posts here - anyone have a recommendation for bulb only?
I'm also now about a month away from my trip - any other things I need to consider? I feel like I'm getting close now!
alpha_omega
Michigan
I think this is from @swathdiver if I’m not mistaken. He and I geek out on excel spreadsheets often shared on here and some of the other similar sites.
Not having a flex-fuel vehicle, did you have to change your fuel trim info via tech2? While this table is obviously subjective due to the amount of miles driven in a year, the temp, driver, traffic, weight, pax, inflation…etc. but did you see a difference (other than knock detection) in say E85 & 87 versus running premium. I ask because you have a 6.2 vs the 5.3.
Same goes for @bobby2175 is there a particular reason you’re not running premium?
It makes no difference to me what you guys run, I’m just asking out of curiosity.
B
bobby2175
@alpha_omega - my Denali is a flex fuel, but I've been running exclusively 93 for the past 7+ years. I used E85 going way back when gas prices were really high, but I had a dealer tell me not to use it because he was saying it "gums up the fuel system". This comment was in relation to my fuel filter getting clogged up on my flex fuel Impala where I was exclusively using E85 at the time. I hadn't used it since.
Right now, seeing people here using it successfully, I decided to give it a try with the main reason to see if it will clean my injectors and resolve a rough idle. But since it seems to be running well, I may keep doing it for the cost save while taking a small hit to fuel economy.
alpha_omega
Michigan
I could be completely wrong, but you might be better off using an actual injection cleaner to do that job, as opposed to using E85. That’s not to say E85 won’t do the job, I’ve just never used it since I have the 6.2.
I’ve always had good luck with Lucas and the ACDelco top end cleaner as well as their injector cleaner (make sure you use the one designed for Flex-Fuel). I’m pretty sure there’s a TSB out regarding this. I’ll have to check my TSB binder. It’s currently in the house and I’m out in the shop at the moment.
BlackBearPerf
Supporting Member Supporting Vendor
Coeur d' Alene, Idaho
That is great to hear! Please so send in a follow-up log with the tune loaded for our review and the tuner can see what he can do about the idle.
donjetman
I my case? No, didn't change a thing.
Pulled up to the pumps, put 5 gal of e85 then filled it up the rest of the way with 91/93. Saved about $5/fillup at the time. Same MPG and performance (conservative driving).
Drewphil
