Just had starter replaced, won't start.... What can go wrong???? FIXED
Ibustbravo
Centennial, Co
Hey, check to see where the battery ground is located. It should be on the engine. And if there's a 2nd ground from the main bat cable, it should go to the chassis. I'd check the grounds on the back of the cyl heads as well.. and any others you come across.
Look on the pic. The fuse left on top, if you look from the side in your car...
That one, where the guy point's on.
Tagged as STUD, whatever that means...
Both of the circuits intended to be powered by the two Studs are optional and are related to towing a trailer. The OE wiring is in place (near the studs) but not connected from the factory.
Stud #1 is designated for the AUX 12v to the trailer. If the correct cable in the OE wiring harness is connected to it and the associated fuse is in place, the AUX pin on the 7-blade trailer wiring connector will be powered at all times. A/K/A hotel feed.
Stud #2 and its associated fuse is there to power electric trailer brakes (full time power), and the underhood connection to the OE harness would be needed. A brake controller must be installed, or wiring spliced under the dash, to send voltage to the electric brake pin on the 7-blade trailer wiring connector.
When wired as intended, these two circuits have nothing to do with ignition or the voltage to run the drivetrain. You might be thinking of the MBEC or LBEC fuses that are in the same row.
nonickatall
Germany
Hmm, sounds logic, but in my case the fuse, the guy is pointing on, was two time blown.
One time when I swaped my positiv and negative poles on my battery and another time, when I worked on my radio, without any shortcut. That leads into not working gauges and i had a christmas tree of warning lights, like ABS, traction control, battery warning, engine lamp and so on.
Probably the picture I found in the Internet of the fuse box is different to the fuse box of my car, because it was surely not the trailer electric fuse.
Now it's in the middle of the night and it's raining, but tomorrow I will look on my car, what fuse it was, which was blown.
The "fuse" that he's pointing to is a dummy fuse (the orange one) for Stud #1. If a real J-case fuse was installed there it would feed full-time voltage to the post that is indicated by the other yellow arrow I drew on the pic below. If that wire is the OE one it goes to the trailer wiring connector, the AUX pin. If something else was connected to the post, well, the voltage would go to whatever was wired. I haven't a clue as to how yours is wired, so YMMV.
Again, in an OE wiring situation that wire is not connected to the study, and doesn't feed anything that is related to the drivetrain. Hence the dummy fuse from the factory.
mountie
mountie
Ok...... This thread is nearly over !! I found the GLITCH...... ( But, not clear when the fuse popped, but replacing it solved EVERYTHING !! I may have popped the fuse when jumping the starter with a screwdriver, when I got home after replacing the starter.....
(( At the shop, after replacing starter,.. a "screwdriver-jump" started the truck....Maybe that is when the fuse popped, but the truck was running, and I drove it home........
But at home, the new " IGN A - 40 a" fuse ( blue color) fixed everything, and, also the few idiot lights went away on the dash, so no need to clear codes.
( pic with red circle is blown fuse )
( Good *****'n grief !! )
Thank you for posting your solution to your issue. Our collective knowledge base has been increased.
Please add the word "FIXED" to your thread's title, to let others who are experiencing a similar issue know that this thread has an identified solution.
mountie
mountie
How do I edit my thread title ??
GMT800 2005 Tahoe Z71
Navy Supporting Member
I don't know how to edit the title of thread ...... I don't see a link.
Go to the very first #1 post of the thread. Top right of that, you can click on the 3 dots and it will allow you to "edit thread". Then open up the title of thread and add the word FIXED.
mountie
mountie
As an admin my menu is somewhat different, but if you follow the instructions from @OR VietVet you should be able to do it. Ping me if you still can't.
I did the edit..... ( as all computers, the answer is there.... You just have to find it.
( I found it ) Thanks........................
mountie
mountie
To finish this thought...... The right-side, front plastic wheel well has a convenient opening, so you actually see the starter. ( Turn wheel to a full left )..... If you must do a manual "screwdriver" start, BE CAREFUL !!! Be sure not to touch one of the big stud-contacts, and the small stud ( signal wire)... That may blow a fuse. Only touch-across the 2 big studs.
Keep a handful of 40 amp fuses in the truck.
mountie
mountie
Sunday evening update...... I'm not out of the woods...yet..... I drove the Yukon the last 2 days, no issues.... It sat in my garage all day today... I started it... Battery nearly dead.... I put a charger on it .... it charged up.... I started it..... The alternator seems just fine
It idled like it has a stuck carburetor float... or the choke stuck....It started to idle a bit better....... Just the 'check engine light' on the dash...... (( WTF ?? ))
I'll see in the morning, if I drive it to that 'troublshooter' ...... Crap !!
How do you know the alternator "seems just fine". The coils and injectors need a properly functioning alternator. The battery may have been down because the alternator is not "just fine" and could either not be charging correctly or is causing a draw that is draining the battery. You also could have connection problems and/or resistance problems thru the cables.
mountie
mountie
The alternator is pretty new & it's not a reman. It shows over 14 volts on the gauge. But it will be checked today.
mountie
mountie
I have a AAA service tech at my house today..... His portable jumper started my truck easily. He attached his 'fancy tool' to the battery, and it looked ok..... He noticed something......
After all the attention to my truck and battery the last few days.....
The negative to the battery was....:idiot:.... sorta loose..... Possibly the reason it wasn't charging properly. Good grief....... I will find out tomorrow morning....
I am not disconnecting the battery over night..... I want to see how the truck is, in it's normal state....
Capybarbro
