Strange start after battery died during oil change, video included
Dustin Jackson
Yesterday I went to change the oil and realized I had the wrong oil filter so I left the Tahoe sitting overnight with no oil in it, no oil filter installed, and the hood cracked open (not full open just resting on the latch).
Today I got the right oil filter installed (filled with oil), filled the Tahoe with 6qts of oil and went to start it. Usually I hold the gas pedal to the floor and cycle the starter for a while to try and prime the oil system. The battery died on me after just a few cranks which was strange.
So I rolled the Tahoe back so I could get my pickup in place to jump start it, I got the jumper cables hooked up and attempted to hold the gas pedal to the floor and cycle the starter like I usually do but this time the motor fired up instantly at full throttle resulting in some terrible sounds. My TPMS light is off so it seems the battery died enough to reset the computer.
My questions are why did it do this?
Does the gas pedal to the floor mode not work when the battery is dead or when there are jumper cables applied?
Would the hood being popped caused the battery to drain over night?
And what was that terrible sound in the video?
Tahoe starts around 30 seconds
Totally flying leap guesses:
The throttle blade was in the WOT position when the system lost power and maybe it had fuel in it for some reason and that was a couple of backfires?
The PCM was reset and didn't know the TB was in the WOT position and allowed it to fire. I don't see how the jumper cables would have anything to do with it. All they do is transfer battery voltage.
I don't see how. GM omitted the hood light and, even still, it'd be controlled by the BCM and shut off after X mins.
Hopefully fuel in the exhaust igniting and nothing mechanical directly related to the oil being "extra" drained.
Dustin Jackson
Dustin Jackson
@iamdub Very interesting about the battery, I only got about 1 crank cycle out of it before it got too weak to turn the motor anymore. I’ll get it tested.
Another thought is that when the computer is reset it might have been trying to use A/F ratios for gasoline but it’s full of E85 causing it to cold start.
Should I be concerned or just keep driving until something breaks?
If it's doing fine now, let it go. If there is anything, it's probably nothing you'd ever find unless you removed and disassembled the engine and maybe even Magnafluxed parts.
I'm betting it was a backfire and nothing mechanical. There's nothing draining the oil would've caused. The internals still have oil in/on them as if it was parked overnight, over a week, two weeks, etc. regardless of the pan being empty. These things are tough and run on the verge of detonating, relying on the knock sensors detecting minor detonation to tell it to back off the timing. Mine broke a spring and bent a valve. Actually, this was a year ago today. I buffed out the piston, swapped the valve (with a used one from a junk a head) and replaced all the springs. After a short break-in, I took it to ~135+ MPH then immediately started road tripping it, including 2,000 miles to Tampa, Florida and back. Even that drive included a few blasts well in excess of 100 MPH and ~6,300 RPM shifts.
donjetman
Maybe?
Leaky injector(s) partially filling a cylinder(s) with fuel so it hydraulic locked when you first tried to start it. Then when you jumped it it did what it did.
Maybe?
Dustin Jackson
Dustin Jackson
That’s a good theory but it’s trumped by the fact the battery ran low enough to reset the computer I think the reason it didn’t start was a dead battery not hydrolocking.
Tomorrow I’ll try to replicate the situation before I go to work, it would be strange to think I’ve been driving around for months with only enough battery for 1 engine start attempt
I wouldn't dismiss that theory. Have your battery tested. It might be strong enough to crank the engine in your everyday normal situation but too weak to overcome a partially hydrolocked engine. The starter cranking the engine is the largest draw it sees. With the engine locked and the starter trying to turn it, that current draw multiplies as it's almost the equivalent of a dead short and that would drop the voltage down to be deader than dead. Your PCM wasn't 100% "reset" as it didn't have to relearn idle, etc. If a combination of our theories are half-assed correct, then it's like the sudden voltage drain confused some of the "short-term memory" aspects but the base maps, etc. stored in "long-term memory" were unaffected.
Dustin Jackson
Dustin Jackson
I had the battery tested and they said everything looked good but the battery “needs to be charged a little bit”. Which is what they said last time I had the battery tested about a year ago so not sure what to do about that. My commute is 20 minutes five days a week so that should be giving it plenty time to charge.
When I got home I attempted to replicate the problem by turning the motor with the gas pedal to the floor and it turned for a long time and didn’t stop so I wasn’t able to reproduce the problem today. I will try again another day after it’s had a chance to sit for a while.
I’ll keep my jumper cables in the Tahoe in the meantime. I suspect the battery might be on its way out and I hope that explains this situation.
EddieC
Just leaving our '08 rear hatch open overnight b y mistake killed our Tahoe battery. Same with the dome light on our Subaru.
It's amazing that with all the technology being designed in that manufacturers don't make the electric controls intervene before something as small as a light bulb kills the battery. Just kill the current. Would that be so hard?
Geotrash
Dave
Richmond, VA
My 2014 BMW had this capability, so at least some manufacturers build in battery drain protections.
Dustin Jackson
Dustin Jackson
@EddieC Depending on how big my tin foil hat is I could say that Interstate Battery is paying GM big bucks to make sure we need to buy a new battery as often as possible
EddieC
In all my vehicle experience, which is way more years than I want to acknowledge, I have had nothing but unsatisfactory performance with Interstate.
I'd pick Wally World batteries over them.
steve45
What does holding the throttle to the floor accomplish? I've only done this on carbureted engines that were flooded. I prime the oil system by putting oil in the filter before installation.
Why did you start the engine on your pickup when jumping your Tahoe? The sudden surge from the Tahoe's starter motor can fry the regulator in the truck.
Dustin Jackson
Dustin Jackson
@steve45 Holding the throttle to the floor on this platform disables the spark plugs and fuel injectors allowing the starter to turn the motor indefinitely without ignition occurring.
Whenever I jump start a car I've always done it with the "rescue" vehicle running, I've never encountered information that suggests doing it differently but I'll do my research on that.
Seamus
Palm Beach
I was told that if the hood is not completely closed the truck does not fully go to sleep, meaning its drawing more keeping all the modules awake. So if the battery was marginal this could be what caused it to run down. A mechanic friend told me that after seeing my truck with a battery tender on it with the hood open.
Dustin Jackson
Dustin Jackson
@Seamus That's what I think, if this Tahoe doesn't put itself to sleep it was probably sending a "open hood" message all night
donjetman
We leave doors, hood, hatch, etc open on our vehicles (07 Yukon, 12 MKX, 07 FJ, 02 Vette, 51 Chevy PU) and never have a battery problem. The body control module in each is functioning properly.
The Yukon has a 5+ yr old Duralast ProPower agm battery that was in the vehicle when we bought it 5 yrs ago.
3 out of 5 vehicles have Interstate Optima batts. We get 8+ yrs from Optima batts.
Candielaine
