2011 Chevy Tahoe 2011 5.3 (6L80 2WD P2723/P0700)
JayDaGreatt
JayDaGreatt
Is this a Dorman TECHM? A few years ago on here, every one of them was a dud. Too bad you turned yours in so early. Never do that!
Its actually a flashed refurbished GM one, i had too without it there was no warranty
JayDaGreatt
JayDaGreatt
Did they say which drum they think is cracked?
And what was the $2800 covering? A total rebuild or something else?
Yes total rebuild, the one that engages 3rd gear & yeah brother i had to try the old one was giving bad readings while pressing the pressure switches
NickTransmissions
Sin City
The transmission bench
Ok, see my list in my 6L80 info thread in the 2007-2014 sub forum (engine and drivetrain) and, if you're considering that shop make sure they replace everything and perform all procedures on that list (they may opt to replace the 3-5-R drum and pump instead of welding the drum and machining the pump) but $2800 seems very low for a proper overhaul.
I charge between $3800-$4500 for a bench build, depending upon whether im replacing the TEHCM or not (ie no removal and reinstallation).
JayDaGreatt
JayDaGreatt
Deff Nick, thanks for all your help & feedback i really appreciate it!
Jaymerkz
