mikez71
Doing a block check test can help narrow it down too. It detects combustion products in the coolant.
Yeah, but at this point with coolant in the exhaust, what else could it be but head/headgasket? (crack in cylinder?)
but either way the tester won't tell me where, I figure head must come off..
for a $20 bet I would use the tester to see what it shows or does not show, you already thought it was the heater core....
I bet it is something under the hood be it head or not when you start it up whatever smell is under the hood gets pushed out the hood right into the nostrils
my hardest one was a literal pin hole leak in a radiator hose it only leaked when you shut the vehicle off for a second and that was it, little piss out and done not even enough to leave a drop on the ground. I think I only found it by accident.
Sparksalot
Bastrop County, Texas
But it would tell you definitively if there is a leak into the coolant. Better to eliminate the easy stuff before tearing the engine open.
mikez71
Very true! I hope you're right! (With my luck it will be head and heater core..)
Waiting for the expansion tank and a couple hoses first so I can try pressurizing again.
I would think with a pinhole that I could still pressurize it somewhat. (Or a small HG leak for that matter)
If no change, I will do the combustion gas check.. certainly don't want to pull the head for no reason.
j91z28d1
I've never had one that wouldn't build even a little pressure. even ones that spray coolent out of a hose. something isn't correct. not sure what, but it's a pretty large leak and above the water line. so that pretty much means how pump attachment itself.
mikez71
Havent done it before, but totally agree!
I'm hoping its the tank seam and will try another tester shortly.
j91z28d1
I don't mean to it to sound dumb but did you block off the over flow hose?
mikez71
I do have a smaller hose from radiator that connects to the tank above coolant level. Did order a new hose as well. Shouldn't have to plug it as it goes to the radiator I hope? I was going to disconnect it but couldnt find the right size plug and gave up.
j91z28d1
I guess yours is different than mine. wonder where the overflow is?
j91z28d1
pretty sure the pressure tester fitting covers the overflow hole, it did on the wife 04 and there is little difference on the gmt800's
looking at the screw on part, the seal is at the very top, how mine is setup. I don't thing it would seal it off. the old school kinda that just pushed down and locked with a half turn it did.
but guess mine is pretty different.
j91z28d1
I assumed it would just leak out from under the cap? idk
yeah, guess so. wouldn't have expected that. everyone I have has a 2nd hose for a to drain any over flow down and away.
huh. gm.. what can ya do
It's a sealed and pressurized system. There is no "overflow" like the older generations. That which looks like an overflow tank with a pressure-rated "radiator cap" on it is a surge tank. That nipple by the cap is to expel what would get by that cap in an over-expansion or over-pressurization event. If coolant is leaking out of that, then the "rad cap" is leaking and the surge tank is too full.
j91z28d1
I get that.. but all 3 of my newer gm cars have it. the yukon and volt have 2, one on both cooling systems.
when I threw a belt at the track on the c6 it emptyed it radiator thru that hose onto the ground. just seems weird for some to have it and others not.
avalonandl
Troy, MICH & Naples, FL
Tried replacing the running board motors on Deathscalade but no dice! :mad: motors are corroded to the bracket so returning the running board motors and reordering the motors with new brackets which are $$$ :mad3: I guess this is the perk to driving older stuff but I was hoping I could replace just the motors and not the motor + bracket since the price increase is substantial
/rant
I gave up on the folding running boards and just went with stationary tube boards
brice715
