Lifters noise
Faustof
Faustof
If you wish, you can post a video of the noise and we can weigh in on likely causes.
Thanks for the interest. I am very grateful. Here are the videos, the shortest and most static, it is the one that was taken cold. The second is after a while, already hotter. Greetings
Faustof
Faustof
I will gladly , but I am having trouble downloading it. Is there a whatsapp number or email where I can send you the two videos (they are less tah 20 seconds each, don´t know why it says is too large). Thanks very much
donjetman
You have to download them on YT and post the link here.
Faustof
Faustof
here are the 2 videos , the one where is no thicking sound is in cold engine in the morning.
the otherone is after 15 -20 minutes
Thanks
Dustin Jackson
@Faustof I hear some pretty good rattle at initial startup that seems to smooth out to a mild rattle at hot idle.
This could be a result of using lower quality parts, possible the lifters are not holding fluid at idle and there is slack between the push rod and lifter causing a lifter rattle.
If this continues after using the correct oil I would not run the motor like this, sound seems to be coming from passenger side.
NickTransmissions
Sin City
The transmission bench
Agree with @Dustin Jackson, change the oil with good quality oil but if that doesn't help, it's time for a valve adjustment (at least that's what id do first once the valve cover's off..
If a valve adjustment doesn't fix it and a lifter has failed, pop both heads off and replace all lifters, trays (oem only for these parts) and check the heads for warpage. If warped, have them surfaced and gone through. Then reinstall everything - make sure you buy new head bolts (i prefer ARP) then install new knock sensors and intake gaskets, etc.
How many miles on the engine?
NickTransmissions
Sin City
@NickTransmissions Can the valves on these motors be adjusted?
You adjust them initially to complete the long block or when putting heads/valve train, etc back on. Its not like a solid roller or flat tapper cam where lash has to be periodically maintained but hydrauic pushrods / lifters can occassionally come out of adjustment but admittedly its rare.
I suggested it as the noise sounds like out of adjustment valves or lifter noise (failing lifter). If there's no valves out of adjustment then he's taking the heads off to replace the lifters (unless we're hearing rod knock or some other bottom end noise but doesnt sound like that to me)
Faustof
Faustof
When I change the lifters and camshaft, the heads and valves were machined and settled.
Faustof
Faustof
Do You think that I Should I change the knock sensor? Do you think it could be the problem?
NickTransmissions
Sin City
Sorry, for My English. Means that since I took heads off, I did send them rectified and the valves too
Did you:
- replace the lifters and trays?
- adjust the valves once you put the heads, pushrods and rocker arms back on?
Also, replacing the knock sensors on these engines is standard fare for whenever you have to pull the plenium for any reason and if they have never been replaced. Not saying it's your problem, its more of a preventative maintenance measure to ensure they dont become one.
Faustof
Faustof
Did you:
Yes, the kit I bought came with lifters, camshaft, trays, but I didn't change the knock sensor. Yes we adjust the valves .
NickTransmissions
Sin City
Got it. Listened to your video again, def sounds like pass side perhaps either #2 or #4.
How long ago was the work done?
Have you done a compression test yet?
Dustin Jackson
@Faustof Your problem sounds mechanical, a knock sensor wouldn’t help.
Do you have a link to the kit you bought? I think at the very least new lifters and lifter trays from a reputable brand would be the first thing that comes to my mind but that’s basically throwing money at it.
Maybe take your valve covers off and see if the rockers have any play in them?
AllyNJ
