GMC YUKON (07-14): XB HYBRID LED HEADLIGHTS-unboxing/output
petethepug
Michael
SoCal
I ran overwattage PIAA super white bulbs in my 06 YXL Denali. They were great. Xlnt cut off, pattern and much more crisp.
Adding stubby HID bulbs would give them superior output but I didn’t find it necessary.
j91z28d1
I just noticed your thread. I've had mine for about 6 months and happy with them. *edit checked and wow it's been almost a year*
like you said they need a good fog light. a little less light than I hopped for, but a nice bi led fog light and I'm very happy.
mines on a black truck and clear lens thou, so they look pretty much stock, just a Gen Gen up. did you do the smoked lens?
pricy, but I factored the price in before buying the truck, as I liked the oem tahoe light look better.
I searched and searched before buying them and your thread never came up. shame, good info here.
annstruck
J and Doubeleive,
You both mentioned 'not as much light'. Can you clarify, are these better than the stock projectors with the best quality bulbs? We are planning our annual coast to coast trip and the stock projectors in our 2014 leave much to be desired at 3am somewhere on I84. At times cautiously trailing semi's to let them light the way. Last time we left maine on friday afternoon and were back in WA late sunday night. Just wanted to double check before we make the investment. Thanks
j91z28d1
J and Doubeleive,
honestly I can't compare them to stock lights for you, I ordered them and had them shipped to a buddy's house near by before I even picked up the truck. it was a few states away. only drove it a bit at night in the city before swapping them. the oem lights where hazed up and someone had put cheap led replacement bulbs in the housings.
I changed them out before the drive home thru the night. I will say they are as good as newer rental cars that I've driven but I have mods to all my car's lights. I have about 800$ into my corvette headlight mods alone. all projectors replaces and added bi-led fog lights to it as well.
so I wasn't blown away, but they aren't bad in anyways. just don't know how much of an upgrade they are since I've not used stock. once I added a set of bi-led fog lights to the yukon. they filled in what i feel these were lacking nicely and since I have the high beam of the fogs wired in to the headlight high beam. I'm happy with it. feel it has proper lights now. but those are not direct bolt on at all. you gotta cut stuff, make brackets and do some wiring with diodes.
hopefully he can give you a better comparison. bit pricey yes, but they do look really nice and seem to be built well.
j91z28d1
here's a pic i took last trip, just bored middle of the night somewhere on a dark bridge in Louisiana. not that a pic tells much, they are so good in low light these days.
this is with the fog lights on thou.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
@iamdub AKA "Swamp Thang" slithers around under that bridge, be careful.
Atchafalaya Basin Bridge? You said NOLA, but I see trees on the sides of that one. Unless it's that one small part near the west end of the Bonnet Carre near LaPlace.
J and Doubeleive,
there are no "stock projectors" for these trucks, that being said yes they are better than stock. I would recomend pairing them with a set of "diode dynamics ss3 max" for ultimate visibilty. (that's another $600) lol
if you look closely in this photo (not the best) but you can see me cast a shadow of the car on my right on the wall and you can see there yellow light right in front of them, the rest is all me and some street lights I suppose.
j91z28d1
I do see the diode Dynamics name around do those have a cut off or they just like a spotlight it looks like a pod like off-road lighting?
j91z28d1
GPS tag looks like I was almost exactly halfway between Lafayette and Baton Rouge.
as soon as I moved it's like I wiped that whole thing from my memory. now I just drive thru it and remember how long it is haha
they are a fog light so wide beam and have a cut off not projector like but close enough, kind of a football shaped pattern I guess
Yup. That's the Atchafalaya Basin Bridge. 18 miles long, IIRC. I don't blame you- I'd love to lobotomize my history here if I were to make it out.
j91z28d1
I went with these bi-led protector fogs since I wanted the cut off for low and then it lifts the shape and gives a nice high beam for that long throw down dark back roads.
annstruck
Thank you both for following up sharing the photos. Much appreciated.
intheburbs
SE MI
They have a cutoff, more fuzzy than sharp, but amazing throw and coverage. They basically throw a wide rectangle of light.
I made a thread a few months ago when I upgraded my headlights and fogs. Some good beam pattern pics inside...
j91z28d1
might be worth doing the fog lights first before messing with the headlights. that might be enough light to be happy
j91z28d1
Have a link for these?
ummm maybe. let me see if I can find the part number. I remember all the youtube videos being from India guys lol. probably got them off aliexpress or something like that.
justinakay79
