Crank and no start no fire from coil
shane333
No fire from coil I can take a ground wire and touch it to the signal wire at the pcm and it tries to start thats the only way it will try to start 1999 tahoe
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum.
Check the cap and rotor for the well known problems they have and are you checking "fire"/"spark" at the wire to cap or wire to coil? Remove the cap and rotor and look at the pickup coil wires to see they are all still intact. sometimes those wires can break over time. If any of them are broken, just get a good quality reman distributor. You may also have a failed ignition module.
S
shane333
No fire at coil I can ground the signal wire at the pcm and it will start
Welcome to the Forum from NH.
Pics of the truck, please.
GTRhino24
I had this issue when I replaced the intake gasket a while back. Turned over but no injector pulse. I was leaning over to check my connections on the distributor and I heard the injectors fire. What? I had placed my hand on the coil to brace myself. Something about the pins on the plugs to the coil were causing it to lose contact. If I wiggled the plugs with the ignition on, I could make the injectors fire. Bent the pins and fixed it.
S
shane333
Via update it was my crank shaft sensor got 3 bad ones before I got one that was good thanks for the help
Eman85
What brand sensors were you buying? Is the good one the same Brand?, if so I'd be worried about it.
Eman85
Standard brand and the good one is acdelco
That's very sad that Standard Motor Products quality is that bad, used to always be the one you could depend on. They do make 2 different lines now to compete with the junk.
I am very glad I no longer attempt to repair vehicles for my living. I don't see how anyone could stand the failed parts aspect alone forget about the learning curve and the cost of equipment.
GTRhino24
Just had a service light a few weeks ago followed by bad idle and firm shifts. Made no sense as everything under the hood is brand new. I replaced every sensor and switch not too long ago. Everything was GM/Delco except one. Take a guess at which one failed. The eBay throttle position sensor. But hey, I saved like $20 for a few months!
bcan
I bought a non-running 2004 Yukon XL 1500 with a 5.3L V8 in March. Crank no start. Mechanic buddy of mine helped troubleshoot. We tested for ground on coil wire, found no ground continuity to frame. Looked for a while at the various grounds around the engine compartment and he discovered a broken ground wire dead center front bottom of engine. Re-attached ground, cranked right up.
scottd
