89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Getting ready for a camping trip with the 2012 towing mule later this week and thought I’d change the oil. Talk about pulling a string. Noticed that my oil cooler lines have gone from a seep to a steady, slow drip. Wait… is that an orange stain below my drivers side motor mount? Fuuuuuuck.
Buttoned up after the oil change and went for a drive. Strange noises coming from my left front wheel. Got home, jacked up that side and sure enough, play in the bearing. Good lord.
So I decided to get it done. Replaced the wheel hub, swapped the motor mount with the Hummer mount I’ve had waiting for this, and installed new cooler lines. All from my new parts stash. 6 hours later and it’s time for bed!
Well done sir!
86k5heavy
I also keep getting a 12" round wet spot under my driver's side floor mat. Pissking me off. Can't tell where it's coming from.
I was having the same wet spot on the drivers footwell. It ended up being the body seam on the A pillar behind the front fender.
I chipped off the old cracked seam sealer about ~15 inches up from the bottom and sealed it back up using 3M Fast Cure Auto Glass Urethane, 08690 (https://www.amazon.com/gp/product/B0038D8OSG)
89Suburban
SE PA
Monz11
Da Burg, Fl
Finally got my backup camera installed. And added about 100 pounds of sound deadening material to the back hatch, cargo area floor, and the area over the rear wheel wells. The camera is great, and I can definitely tell the difference with the sound and vibration while going down the road.
did you replace it with stock or upgrade?
Trilla_one
FL
I’m torn on the clears- not just those but all of them. . On one hand I think they look sweet but on the other hand I think they look like something’s missing.
I agree but I also like how they set the vehicle apart from most others lol. The first pic makes them look more clear than smoke. Overall I like how they came out
wwiizz
