Exhaust manifold tick?
iboughtatahoe23
Hello. My manifold stud broke off in the drivers side closest to the steering wheel, it seems to have started ticking too. It appears to be coming from under though and I don’t feel or hear anything at the broken stud area. I don’t feel the leak there. What y’all think? Where else could it be coming from? Video Here
Dustin Jackson
I would first address the broken manifold bolts.
A trick you can use is to tape a shop vac to the exhaust (tape the other side if you have dual exhaust) and set the shop vac up to blow and use it to pressurize the exhaust pipe and then try to listen for a leak or spray soapy water around where you think the leak is. If there is air escaping it will cause bubbles.
With me just being on the internet there is only so much I can speculate without seeing it myself
ivin74
05 NBS Nali
Htown, Texas
You have a broken manifold bolt, its ommon issue. They sell a bolt that attaches to the head to Tighten up the manifold back to the head
j91z28d1
I'd do this and see if the noise goes away. it's a cheap part from Amazon or advanced auto parts has them local usually.
I put one on the back drivers side on mine because I didn't feel like fixing the bolt right now. on my c6 (they snap bolts too) I was changing manifolds, so I did the weld to it and take it out trick. but the truck, until a have good reason, the braces work well for cheap.
iboughtatahoe23
iboughtatahoe23
i believe it is broken off inside the head or something.
iboughtatahoe23
iboughtatahoe23
What part of the manifold are you referring to? I’m not familiar with the part you showed me. Is that the bracket that attaches to the exhaust from the manifold? I’m talking about (this)
j91z28d1
I'm sure there is on YouTube. but super simple. they bolt on to some existing holes in the head, and then a bolt on the bracket is tightened and it pushes against the exhaust manifold. it takes place of the broken off bolt.
there's not much to it. they sell different ones for different locations of the broken bolt. you leave the broken bolt in the head alone.
mikehooo
I’ve had a plug wire ark and it tick much like an exhaust leak. Hard to pinpoint sometimes.
Merch619
