Jstew913
- Joined
- Sep 4, 2022
- Posts
- 3
- Reaction score
- 11
Put on my 22’s today and remove ed the lowering kit
Looks like it’s lifted.
Yeah I took the lowering kit off and lifted it with keysLooks like it’s lifted.
Must have spacers in the rear too..? And youYeah I took the lowering kit off and lifted it with keys
Did you replace the rear with a junkyard unit?Installed the new covers in wife's stahoe and yes she wanted pink stitch but it doesn't look bad in person.
I also replaced 3 of the 4 of window regulators in my suburban, Waiting on other parts for the last door to do last one
And replaced that grenade 80, was worried about my 5 speed trans, seems like everything is fine so I'm running with it
Yea, also replaced all bearings and reused my gearsDid you replace the rear with a junkyard unit?
I am sure we have all had our times, where someone else was (hopefully, unintentionally...) on the receiving end of some anger or stress from us.I just wanted to apologize to any of you that caught wind of my rampage the other day in this thread. I’m having some personal issues in my life right now that I have very little control over and I took it out on a forum member. I was acting petty. I’ve sent an apology to that member and wanted to extend it to all of you.![]()
They look cool! Brand information is not visible, so hard to have anyone identify if they are a product that was good quality or not...I previously mentioned that I need to get some new running light/turn signal housings. What's you guys opinion on this headlight and running light combo? I'm definitely intrigued, but I don't know what they'd look like in person. I also like that bowtie-less grill in the picture, but that's most likely a Photoshop. If it's real, I'd like to know where I can find one. View attachment 395445
Thanks! I went with the moog z71 replacement springs in the rear when I deleted the factory air ride.1-3 inch lift torsion keys. And yes spacers in the rear. And yes dipped the grille and caps…Must have spacers in the rear too..? And youpulled off those crappy chrome mirror caps. Plasti-dipped the grille, and mirror caps? Looks great!
Try supporting 4x GMT800s, a Town Car, and a Kia; add drivers who do not want to be without their car to let you do maintenance...That's some nice glass ... Well I just opened up my liftgate to mess with my rear A/C and I noticed this bullspit. FML I can't win with this Tahoe... I try and treat it right but seems like every time I fix something I turn around to get 2 more things that have failed or are beginning to fail....
Oh.. that’s really too bad… um.. yeah.. costly.. but. While you’re in there…Still dealing with a p0302 misfires. This weekend my buddy threw his scanner on it and did a running compression test which showed about 150 psi on that cylinder. He noted the exhaust stroke was slightly below 0 psi and thinking either collapse lifter there or one starting to fail=/. Will do a leak down test tomorrow or Wednesday.
I'm now shopping for a cam kit!!! Haha!!
Brian Tooley BTR Truck Norris LS Camshaft for Gen 3/4 4.8L 5.3L 6.0L LS1 1999-2013 Cam Kit
Upgrade your 1999–2013 GM Gen 3/4 LS engine with the BTR Truck Norris Camshaft Kit. Designed by Brian Tooley Racing, this camshaft delivers increased power and torque across the RPM range, featuring a 212/22X duration, .552"/.552" lift, and a 107 LSA. Compatible with 4.8L, 5.3L, 6.0L, and 6.2L...www.michiganmotorsports.com
And some ls7 style roller rockers and pushrods. Will see what happens.
Yeah but I'm well over 300k miles. I kind of like the truck and plan on giving it to my son when his DL arrives in about 3 years. Plenty of time to mess with it now. I might have my buddy refresh the block itself depending on the leak down test resultsOh.. that’s really too bad… um.. yeah.. costly.. but. While you’re in there…
Truck Norris go BTRRRRRRR! LolStill dealing with a p0302 misfires. This weekend my buddy threw his scanner on it and did a running compression test which showed about 150 psi on that cylinder. He noted the exhaust stroke was slightly below 0 psi and thinking either collapse lifter there or one starting to fail=/. Will do a leak down test tomorrow or Wednesday.
