Geoffsfas10
Well this is weird...today it got cold and rained. Drove tahoe to work, everything was fine.
Went to leave work, acted like dead battery, one crank then gave up. Pulled key, tried again, it tried to start but the timing of the starter was real weird. Then it turned real quick and started up. Was fine once running. Drove it home and parked it, started right back up.
Went to go on an errand a couple hours later, no crank start, pull key, multi-meter on battery..12.2V...tried again and started right up.
Went to Autozone, did battery check, 96& charge and cranking amps were fine. Started fine there, went to store, started fine there.
Texting the shop who did all the work, they think I have a weird ground somewhere from everything being apart, and possibly the rain was effecting it. It was after hours, so we're going to work out troubleshooting it there tomorrow. Will be interesting to see if it starts no issue in the morning once its dried up.
It was a loose ground bolt on the passenger side head....found out putting my MIT on....
