Bad start to road trip!
hertahoe
Washington
So got the oil changed earlier in the week at dealership (free lifetime oil changes), had dealership rotate tires and I put on new wipers. No running issues since last April on another volleyball road trip when my transfer case had issues and an ignition coil. So about two hours into a 5 hour trip, crap went crazy. Doing 60mph, slowed down to around 30 for traffic and started to accelerate and ABS and brake light came on and would not shift out of gear. Speedo was bouncing between 30-50 and I could get it to 40mph with rpm's around 4k. Got over to outside lane and took exit. Drove about a mile at 35 to get into decent area to park. Turned off, restarted fine, but lights still on. Didn't have my code reader. I had to get to destination for my daughter and her friend. So found a rental car agency about a mile away. Drove to it, rented car, left Tahoe in lot and drove to Eugene. So now I'm looking for the exerts to try to trouble shoot what the hell is going on. I will try to respond when I can, but will be attending volleyball games all day long until Monday night! My plan is to drive back to Washington on Monday night, then drive back down Tuesday morning to take it to shop or fix if I don't need to remove engine :) Much appreciate all the input!
We'd have to write books to suggest all that could be wrong. First step is to get a scanner on it. If even to drive it to a nearby parts store to borrow one. My concern with that is if it's intermittent and the fault(s) have cleared, the codes could go away during the drive to the parts store and you'd be left in the dark until the problem returned.
Guesses off the top of my head- failed sensor or related circuitry telling the PCM erroneous info and it responding to it as programmed. Bad MAF, MAP, TPS, VSS, etc. Something that provides the PCM with vital info has thrown it for a loop with info that doesn't fit. Or the circuitry in between has cut power and/or coms between the PCM and sensor.
If multiple sensors and/or systems failed at once, see what they all have in common. This is usually a ground. Are there any other seemingly small oddities that have occurred prior to this that you haven't mentioned?
hertahoe
hertahoe
Washington
Much appreciated. I know at this point it's throwing mud on the wall without a scan.
nonickatall
Germany
Sounds to me like an ABS Sensor failure. I don't know how GM made that at the Tahoe, but I know that from many German cars that the speed signal comes from one ABS sensor, mostly the one in front on the right side.
If this sensor makes trouble, you probably have a bouncing Speedo and you have no acceleration because your ECM and you transmission control need that Signal.
I think it was the failure of a sensor, because when you shut down the engine and start again and everything runs fine, looks very much like that.
Normalwise ABS Sensor failure are security related, so it stays in memory and your ABS light stays in.
But it's only a suggestion
ScottyBoy
Shreveport, La
Not sure a
That does sound plausible. I know when you have a bad ABS sensor, it can mess with the speedo, trigger an ABS light, Traction Control light, and even a "Service 4wd" error message if you have 4wd.
I've never heard of the transmission not wanting to shift though, but I guess it's possible. If it does turn out to be bad ABS sensors in the front wheels, I strongly suggest you just replace the entire wheel bearing/hub assembly. It's easier to change the entire assembly, as the hub assembly needs to be removed anyway to replace the ABS sensor, the ABS sensor is included when you buy a new hub assembly, plus the cost of an entire hub is not too much more than a bare ABS sensor. Let just hope it's something as simple as an ABS sensor and not a transmission issue.
hertahoe
hertahoe
Washington
Well, drove down to Portland to return rental and get Tahoe to shop. Scanned it and abs control module...Nice little indy shop and guy was great. He scanned it multiple times and cleared codes. I would take it around the block to see if lights came back on and they did. Apparently there was no info coming from sensors. He believes it's a bad abs control module. Basically ran out of time and I ended up getting a hotel nearby. Drove car to hotel at 35mph max. He is going to run tests on the circuits before putting in new module to make sure its bad. At first look over, he saw the plug to the module barely connected. Secured it back to plug, but didn't solve issue. But it is a costly part! Hope it solves the issue so I can get back to family!
PS - daughter is the starting libero for a U16 national team in our home town. First year the girls are together and they took 26th in the gold bracket outta 150 teams.
nonickatall
Germany
Possible is it possible to remove
I don't know the specific control unit, is it possible to remove the circuit board separately? If so, I would try the following.
I would remove the circuit board and bake it in the oven for an hour at 230° Fahrenheit.
That sounds strange at first, but it often helps to repair circuit boards, because it is often the cold solder joints on the circuit boards that cause the errors. At 230°, the solder becomes soft again, reconnects and you can save a lot.
I recently got an expensive engine control unit from a classic car, that is no longer available is repaired in this way. Your control unit can't get any more broken. Otherwise I would also consider installing a used one.
hertahoe
hertahoe
Washington
Owner of shop happen to stop by. He suggested taking out module and take it apart. All the torx screws are rusted, so they have to take the whole ABS unit off, which means bleeding the system. The Tahoe has almost no rust, but always in the wrong spot at wrong time.
hertahoe
hertahoe
Washington
More bad news. Module put in, brakes bled, but ABS light came back on and speedo still bouncing. Truck can go over 40mph though. They think when the transfer case was replaced (4/22) that the shop didn't calibrate it to truck. If I drive it, more than likely, it will burn up new module. Another interesting issue. Scan keeps saying there is a speed sensor on the rear wheel but there is none. Only speed sensor is on top of transfer case. Now I'm getting concerned and pissed for the amount of time I am wasting. Looks like another night spent in hotel. FML
Mudsport96
40.923,-89.488. Illinois
Could be bad vehicle speed sensor flaking out and giving a bad reading to the abs module. My Tahoe has the rear axle speed sensors for the stability control and traction control. And it is an 06, you sure your 05 doesnt have them?
ivin74
05 NBS Nali
Htown, Texas
I have never heard of such thing on the NBS body style.
Sound like the shop does not know what they are doing.
You sure they are not getting confuse with the rear abs sensor.
When people wanna kill the traction control in these things for burnouts or drifting, simply pulling the ABS fuse kills these systems. My thoughts are that if you pull the fuse and it drives like normal again, then this will (1) get you back on the road and (2) confirm that the ABS and/or TC system(s) are faulty. Just know that you won't have any of the safety systems, so don't tailgate or do any other risky driving.
Mudsport96
While i agree, the bouncing speedo screams bad speed sensor to me. And if it is not synced with the from wheel sensors the abs will go bonkers.
hertahoe
hertahoe
Washington
So when they scanned the truck, it said there should be a rear speed sensor on rear wheel. I looked just as two different mechanics looked, nothing. But there is one on the top of the transfer case. Here is where it gets interesting. Tech ordered part associated with vin# and it wasn't the right part. Manager drove over to dist center to get right part. They gave him same one. Said it is for a manual transfer case...Is there a manual transfer case that would fit my Tahoe? Tech said there are some vids with the code that causes issue of ruining the control module. So I called up transmission shop and the guy says they are interchangeable. I think I got scammed.
rockola1971
Indiana (formerly IL)
By "manual", they mean that your Tcase does not have auto 4wd. You should just have 4Hi, 4Lo, N and 2wd for buttons. You should not have a "Auto" button at the top of the others. My (2) 03 Tahoe LT's have Auto, 4Hi, 4Lo, N and 2wd. And your VSS(Vehicle Speed Sensor) should be on your Tcase...Unless you have one of those funny German Tahoes. ;)
I swear I read that the shop ruled out a speed sensor. Went back and re-read and saw that nothing like that was ever mentioned. *facepalm*
What you're saying makes sense.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
In fact you may have two sensors in the tail of the transfer case.
hertahoe
hertahoe
Washington
Mine does have an auto button. Don't make fun of German cars. I had an A4 B6 that was the reason for all my gray hair! :D
briannorris
