wjburken
Eastern Iowa
Not a oil leak even though it looked like it wet, explains why it looked rusty, it's the right motor mount leaking the funky fluid out, time for another hummer mountView attachment 384323
Crazy that you’d have a broken motor mount. It’s not like you push it to the limit…..oh wait. Yah, it makes sense.
Already did the driver's side so I'm actually surprised the other side broke I can't feel any difference tight as a bug in a rug, maybe because it happened recently it still has some strength left
Beats an agonizing oil leak mystery!!! Good job man!
ya, I was kind of surprised to see that but relieved that it wasn't a oil leak this engine is too new for leaks, for as much as I beat on it though all I have had is one broken exhaust manifold bolt. I had just cleaned and pressure washed everything about 3 weeks ago so I figured any leak would be pretty easy to find
Charlie207
LFOD, New Hampshire
My guess is that the passenger mount compresses when you hammer the gas-pedal, vs. the obvious drive's-side lifting up.
Unless you have a rare counter-rotating crankshaft, RPO code: WFTLOL2
Fubar0715
Scott
Southern New Hampshire
Is that RPO for the Silverado? I think the code for the Tahoe/Denali/Esky is WOTLOL2 - I tell ya, this forum provides SOO much information/knowledge sharing that an average person would just be lost without!
m1dn
Dropping the oil pan is really no big deal on one of these, even with 4wd/awd. I've done it 4x over the past few years for cam swaps, oil pickup tube seal, etc. Drop the crossmember, drop the sway bar, drop the steering rack and let it hang from the tie rods, remove the passenger side CV axle bolts and diff mount and let it hang down... boom, plenty of room to get the oil pan out. With the truck up on jack stands and with an air impact wrench in hand, I can drop the oil pan in under an hour. But my guess is that your leak isn't from the oil pan. It's much more likely to be coming from where the oil cooler lines go into the block above the oil filter, the valve covers, or the VLOM plate.
That's actually very good advice, thank you!
Valve covers might have never been off, it won't hurt taking them off, cleaning everything, replacing the gaskets and maybe even coils?
And check for any possible rocker slack
Will add to my todo list and get it done sometime next week mornings, Ontario teachers are on strike starting Friday, so that's few extra free hours for not taking kiddo to school
Charlie207
LFOD, New Hampshire
I wish I had the courage to do a DoD delete with a new cam in my gravel/dirt driveway on my daily driver.
m1dn
I LOVE this forum, thanks again!
Was taking off headlight to remove moisture and reseal and what do you know, decided to "touch" the 2 bolts that are reachable on the VLOM plate ( non-DOD engine ), the both bolts are loosy, did some tighty for now but will be taking off the top to clean it up and make sure all other bolts are TIGHT.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I hope yours aint as bad as mine was. I had one or 2 tight bolts the rest were all fkn loose. Bleeding to death inside and out.
m1dn
Looks like these engines just go in the heat and love to leave marks everywhere they go so other "male" LSes can find them easily.
Did you have to do anything else besides cleaning it up and tightening the bolts?
89Suburban
SE PA
I had to replace the whole VLOM assembly because it is riveted together and you can't replace the gaskets on it. So make sure you do your homework parts searching. There are a few different gasket designs. The firs two I ordered didn't match. And I come to find out the gasket on mine is riveted into the VLOM assembly itself so I had to buy that instead and lost the money I spent on the damned gaskets because they would not accept them for a return. The things are pricey.
I will say once the VLOM was replaced with a new one it breathed some new life into the motor and ran MUCH better. I also had an issue on the first cold start with running rough and misfire codes. I revved the hell out of it out of frustration and it cleared right up. It's my gut feeling it took a while for the air to get purged out of the VLOM.
Also might as well replace the oil pressure sending unit and screen, and steam port gaskets while it is apart (2 in front and 2 in back.)
m1dn
Do you have parts number still by chance?
Looking at Rockauto, it's hard to find VLOM or VLOM Gaskets for 2008 6.2 ( non-dod ), it lists different looking parts, mostly complete VLOM plates it seems
I guess intake manifold gaskets would be another good idea while i'm down there?
the non dod are flat i believe, the dod have ridges
ASG-MikeS
