Heater Hose "T"
Blk00ss
Wasn't sure where to post this. Our '05 Tahoe has sprung a leak. Its coming from the white "T". I did get a new GM "T". Any advice on getting these off. I realize they have clips you squeeze, but me and GM don't have a good history with these clips. I know many people fail with these because they don't push in first, then pull off. But based on lots of reading it seems this job kind of sucks especially with how close it is to the firewall and under the windshield. Just looking for any tips ya'll might have
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I always have issues getting them apart. No damn room to get in there. I use a flathead screwdriver and/or a long pair of needle nose pliers to break the thin black pieces off holding the white locking tabs. I just replaced both of mine back in July. Use GM parts not the Dorman stuff. You need the 2 tees and there is a connector for the inboard hose. Here is a parts list:
Here is a pic of mine installed. Black is outboard white is inboard. The steel lines coming up pretty much line themselves up where they should be but you can mark them with a marker for orientation in reassembling if you wish.
B
Blk00ss
Good info. Like an idiot, I didn't get the black one. I kind of panicked and just ordered the white to get it here since I'm gonna be out of town laster this week and I didn't want my son stranded if I'm not here.
So you did clamps instead of the stupid clips? I was actually considering doing that as well. Any idea what size and style clamps those are? Can you get them at any auto parts store? Did you just run the hose up and over the flange (I guess is what its called. The raised area?) and then use a clamp?
I used a hacksaw blade to cut off the tabs (as stated above). I tried a few different 'tool' made for that purpose, and they failed. Be sure to wear gloves, as that firewall insulation will itch your hands for a few days. Do NOT buy Dorman replacement Tees.
B
Blk00ss
I think I'm more concnerned about these plastic hose clips where the hose itself clips onto the T. I guess I assumed the new GM "T" would come with one. I was wrong
BatsTDK
Orange County, CA
This is the second time I've done this bear of a job. I just hacked away with a saw and screwdriver until they broke off. Like the others said, just replace both black and white while you're there. No sense in doing the job twice. Black one will fail soon.
89Suburban
SE PA
There is no going away from those plastic clips unless you do a full delete and swap over to hoses, clamps and metal tee's.
Take some time to check out this info from my brotha from anotha ***** @iamdub .
B
Blk00ss
I appreciate all the advice. But this was not difficult at all. I'm not trying to be rude, but it really wasn't hard. Of course, I do all of my own work to all our daily drivers as well as my muscle cars I've owned. To give an idea, our Tahoe has 173K on it and those lines have never been changed. We've owned it since 20k miles. I think where most people go wrong are how they go about disconnecting the clamps. You have to push in first, then squeeze the tabs, then pull hard and they typically pop right off. Some will break due to age and constant hot/ cold. And I will admit, I have had some like the fuel charcoal canister clips that DID NOT want to come off. But these came off with little to no effort.
89Suburban
SE PA
Ok you are blessed then, hat's off to you. So you said the white one on the inboard side was the one that failed? What about the quick connector from the heater hose that clips onto that tee? That bugger is well known to fail too.
B
Blk00ss
Ok you are blessed then, hat's off to you. So you said the white one on the inboard side was the one that failed? What about the quick connector from the heater hose that clips onto that tee? That bugger is well known to faYeah, after some more reading I think m
Well, I thought it was the white one. When I started to try and disconnect the white one, I noticed the black one dripping. The issue with that is I only ordered a white genuine GM one. But I needed this fixed because my son needs his truck this weekend, and I'm leaving town. So I had to go buy a damn Dorman black one because I have to order a genuine GM black one. Yes I know, the Dorman ones can leak, but seeing as how these ones were the factory 173K ones, maybe this Dorman one will hold us over until I can replace it with a GM one. So basically I have new GM white one and a Dorman black one.
As far as the clips are concerned I actually had a grey one inside the GM heater hose I ordered years ago when I thought it was leaking way back then. That GM hose has been sitting on my shelf for years because back then the leak ended up not being that hose. But to my surprise, it had a replacement (never used) grey clip that clips onto the outboard black "T". Apparently Dorman makes the clips also, PN 800-407. It comes with the small clip and a larger one. So I used the grey GM clip from my heater hose I never used to connect to the black "T" and I used a white Dorman clip to connect to the white GM "T" i used
I'm glad that your project went very smoothly. You are an outlier, but I'm happy for you.
As stated above, the new Tees should come with a new clip. Mine did.
Remember to replace the Dorman Tee when you gat a chance, because if the Dorman Tee grenades, you will lose 75% of your coolant within 60 seconds.
B
Blk00ss
Yeah I will. Yeah, neither T came with the clips that bring the hose from the pump up to the T. It had the clips that go onto the core and the steel lines, but not the clips that go inside the hoses that connect at the front of the T's.
For anyone doing this job, I found it helpful to twist the connections a bit. On mine you could actually hear and kind of feel as if it was breaking a seal. I'm sure after all these miles those plastic Ts try to become "one" with the steel lines and the core connection
ScottyBoy
Shreveport, La
I replaced both my T's and the quick connects that plug onto the T's, all with Dorman parts. I replaced them all back in 2017 and so far they are still holding up just fine. To remove the old ones, I literally used a flat blade screwdriver, a utility knife, and some small *****/wire cutters. I tried the actual release tool but with it being so close to the firewall it's damn near impossible to get the tool in there to release the tabs. So I started cutting and hacking away at the old T fitting and removed it in small chunks until I got it all off. Another tip I read somewhere: use Silicone paste/grease (same stuff you lubricate brake caliper slide pins with) to lightly lubricate the O-rings on the new parts and they will slide on easier and be less likely to leak. Just don't use petroleum based grease, it can degrade rubber parts like O-rings, and be sparingly with it, you don't want blobs of it to get into the cooling system.
I replaced mine and was messing around with the one that had a quick connect hose end that connected to the T- I was able to remove that section in one piece because I didn’t need to disconnect it. This allowed me to play with releasing the thing, then clicking it back on, and releasing it again. I noticed that if you squeeze the tabs and then twist, the connector itself holds the tabs in because they’re not in their release slots. Then just don’t turn it back to its original location and the tabs won’t snap back out. Just wiggle and pull. I tried this with the new hose where it connects to the T ( I had already installed all the new parts by now) and it worked great. If anybody else is doing these, please give this trick a try and lmk if it works for the T’s because I think it will. I just don’t know if there’s enough room to twist them.
MassHoe04
Western MA
That's a great tip to keep in mind!
Darrski27
Atlanta
Thanks for all the info! My black one just started leaking. Dumb question, is it possible to replace them without draining all the coolant first? Trying to avoid more work if it’s not necessary.
MassHoe04
Western MA
The connections are up high in the system, so you shouldn't lose too much. Top off the reservoir when done and check again after running a few trips at temperature, in case it burps any air out. Top off as needed.
You can try to keep the loose end of the hose pointed upward (at least at an angle above horizontal) while the fitting is replaced, to keep all of the coolant in the section of hose from pouring out.
89Suburban
SE PA
Yup. You can also pinch the hoses shut.
5strmtrp
The black one snapped clean off today on my son. Weird thing is it also has a compression fitting on the hose that goes down to the water pump. All suggest the GM one, I see the part #’s here. Gather the white one is around the corner to fail as well. They are a pain in the butt to disconnect. ???The new fittings they come with the plastic tabs or do I need to order them as well??? This truck needs to be back up n running like 4 minutes ago.
a1parrothead
