Spare tire - Access panel
pa31p
Maybe this is a little much but..
The panel that you open up to lower the spare tire. I’m sure in a panic you’d be tempted to shuff a screw driver in that panel and crack it open. damaging the paint in the process…
Anyone has a handy tip to remove that access panel without damaging the paint ?D9689429-F7A1-43D4-A351-2BEAFA8D1FAC.jpeg
Multnomah Falls
Military
Hell, you would think GM would supply a tool for that, maybe included in the area where the jack and tools are.
d_hawk
Anyone has a handy tip to remove that access panel without damaging the paint ?View attachment 381402
Small flat blade screwdriver with a wrap of electrical tape on the tip has worked for me. I have removed the access panel to lower the spare tire 3 times now (twice to check air pressure and once for a flat).
Multnomah Falls
Military
I would also assume the owner's manual makes a recommendation for the cover removal.
d_hawk
Owners manual leaves it to your imagination on removing the access panel
ajdahl8660
