Spare tire - Access panel
pa31p
Maybe this is a little much but..
The panel that you open up to lower the spare tire. I’m sure in a panic you’d be tempted to shuff a screw driver in that panel and crack it open. damaging the paint in the process…
Anyone has a handy tip to remove that access panel without damaging the paint ?
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
Hell, you would think GM would supply a tool for that, maybe included in the area where the jack and tools are.
d_hawk
Anyone has a handy tip to remove that access panel without damaging the paint ?View attachment 381402
Small flat blade screwdriver with a wrap of electrical tape on the tip has worked for me. I have removed the access panel to lower the spare tire 3 times now (twice to check air pressure and once for a flat).
OR VietVet
Willamette Valley
I would also assume the owner's manual makes a recommendation for the cover removal.
d_hawk
Owners manual leaves it to your imagination on removing the access panel
Stbentoak
It would be nice if someone would make a short video of doing this correctly and without damage so we would know just wat to do when needed.
St. Louis
There's a small slot on the left hand side of the panel. You can see it in that pic, and the arrow is pointing at it in the owner's manual pic posted above.
Kind of like on some of the center caps on some of the wheel models.
Blackcar
Like been said there is small slot that can be seen on left side of removable panel a screwdriver with electrical tape on end will remove cover or like been stated plastic trim tools but that small slot on left side is your helper to keep from marking paint. I would try before a have to case they don't come out that hard.
pa31p
pa31p
Won’t let me post a video, but I found this plastic tool in my iphone repair kit. works perfect pops right out, as was suggested above by trying this , an interior tool would do it just fine.
tom3
So that's what that panel is for. I figured it was for a trailer towing connection or something. Thanks to all for posting about this!
Drewphil
