George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
These damn raybestos e3 combos I bought are squealing like pig. I'm thinking of sending them an email. It's all 4
Mine did too for a while. They have quieted up now. I also use this stuff religiously.
Edit: I still don’t like the brakes… wish I had bought power stop stuff.
Crazy old basterd. I’m stubborn as hell but if I’m dragging a foot I’m going to the hospital. Hoping for the best.
I hope all is well buddy. I'm glad you were proactive
Way to be ON IT. You did exactly the right thing and timeline is crucial. Hope the MRI is in his favor too and gives y’all something to work with for treatment.
Thanks, broskies. Latest is that the MRI showed an actual stroke and not the best-case TIA we were hoping for. But, still a mild stroke. As of this morning, his right side is usable. Docs said it will likely come and go and they already have him on rehab/physical therapy. They said it was triggered by his diabetes.
A relieving factor is how efficient the hospital has been as a whole. I'm quite impressed. With how the healthcare system is, especially in Louisiana, this was not expected.
justchecking
Military
SW Ohio
View attachment 380168View attachment 380169
Today was opposite day. Went ***** shooting and missed the first THREE birds. Decided to put an LED light strip I bought for the rear (can't put it in til the rear is fixed from the crash) as an under-hood light. Drilled the switch mounting hole off which caused it to bind so I decided to drill it out. Drill caught which caused the switch to spin into two pieces. Prepared another switch, laid out my wiring and then forgot to install the woven wire cover over the wiring before I crimped the connectors. Decided to put the + ring terminal on the right hand fuse block stud and couldn't find my 10MM SOCKET. Wife brought home paper work for a new FORD EXPLORER!
Four Roses was not involved...until now. :rolleyes:
Went to the range and stopped at the S K E E T field. Asked around and NOBODY ever heard the other meaning of S K E E T!
Also went some mild off road checking out our hunting spots in SW Ohio. Got to use 4L for a while; maybe first time ever for this vehicle.
CaptainAmerica1
Arlington TX
View attachment 380644View attachment 380645
Forgot to razz ya the other day over this censoring!!! The other usage is from the 60s I swear rofl
m1dn
This week:
- Wash, Wax
- Tailgate Actuator fix
- Parking Brake fix
- Tow/Haul Mode wire fix
- Oil
Next week ( parts on order, RRRRockAuto ):
- Tranny Oil
- Air Compressor
- Spark Plugs n Wires
Need to also figure out something with wheels in next few months, "chrome" is gone from all of them.
Will be scraping Facebook marketplace, maybe hop over to Detroit/MI and pick something up from there, since there are barely any options on Canada side.
m1dn
Was thinking of replacing o2 sensor this morning, it throws an error every 400km roughly.
Called two local part stores, both said 120 plus tax CAD for downstream sensor.
I asked if they were joking, guess I’ll be ordering all 4 sensors for under 100 from rockauto.
Love canadian car and boat parts prices.
RooTBeeRthe1st
Well, dropped $430 shipped from summit on the 250A MechMan.
Should be here in a week(9 in stock).
Seemed like the best option, OEM sized pulley for high revving capability, but still makes 180A at idle.
Should be good to go after.
Still need to grab some wires and do the "Big 3".
just been driving it all over it is about time to do some intake cleaning and inspect everything underneath, probably have to lube the sway bar bushings soon since the weather is going to change. On the fence about buying new tires yet or not
justchecking
Military
SW Ohio
Little things count
Also, at the S K E E T range today I got lot of comments. I.E. "Did you know S K E E T means when you ***** on your *****" or even "***** with your *****" and ESPECIALLY "when ***** on Thursdays"! I don't know if anybody will EVER shoot S K E E T on Thursdays ever again!
Merch619
