Will Carlson
I finally figured out how to get the knobs for Toyota Tacoma to work. And put them on. Really like them. They light up nice with my leds and really add to and change the look of the interior. Posted up some pictures of them lit up so everyone can see what they look like. Decided with this instead of the Escalade knobs being they’re so hard to find and for $20 of Amazon not too bad. Also like them a little better they’re more fancy in my opinion. Not exactly a direct fit. You have to take the metal pieces out of the old knobs and put in these knobs and glue the pieces into place and take a dremel tool and dremel one to mimic the plus sign for the headlight switch. What’s everyone think?
The knobs themselves look nice but I’m not a fan of all the colors. The only one I like for interiors is white or blue. Good work though. I was lucky enough to get Escalade knobs for all my controls.
S33k3r
Dallas, Texas
Can I just say "very jealous" to answer your question? :cool:
@Rocket Man Good luck Mark. Hope for the best. Bob
Hey @RAMurphy when your ac system got metal pieces in it and you had to flush it, what did you use? I’m wondering that since mine has a leak and so at the very least it must be contaminated, is there anything I need to do to flush it when I replace everything. Alldata states to immediately cap the lines when a component is removed and since mines leaking…am I being too worried? Maybe I just need to recharge it afterwards and not worry? Alldata states to use a special tool to flush it with but I don’t have access to one.
RAMurphy
Bob
Military
S. Maryland
@rocket Of course this was like 10 years ago, but I used a product like this - it may actually be what I used:
https://www.amazon.com/Interdynamic...ords=a/c+flush+solvent&qid=1660995710&sr=8-36 t
I do know I used several cans and compressed air (very low pressure) to force the flush further into the system. Let it sit for a while. Then used compressed air to dry it out. I went both directions in the lines and multiple times. I have rear A/C and that took the longest. I opened up the system in the back and did the same thing. When I ran the flush through it the first time, I actually could see small shavings in the rag on the other side of the system when I was blowing it dry. Like I said took most of the weekend. My compressor was put to the test. I then put it all back together with new seals/o-rings. Took it to the shop I use and they put a vacuum on it to pull any air in the system and what not and then filled the system with freon. Been operational ever since. Again, Good Luck and hope what you find is minor.
https://www.amazon.com/Interdynamics-Conditioning-Aerosol-Cleaner-Automotive/dp/B004BSHVUY/ref=sr_1_36?adgrpid=1344703285165965&hvadid=84044204089433&hvbmt=be&hvdev=c&hvlocphy=88739&hvnetw=o&hvqmt=e&hvtargid=kwd-84044300139822:loc-190&hydadcr=6370_13218902&keywords=a/c+flush+solvent&qid=1660995710&sr=8-36 t
Well of course mine is worse case scenario. I feared as much. I did find the leak though- the high pressure switch was blown off the back of the compressor. There was not even any oil left in it. And the orifice tube is packed with metal. Arrrrgggghhhh. I quit for the day. I did get the compressor mounted, those two bottom bolts are a bear.
I ordered a flush kit off Amazon,one day delivery. Ill chronicle this in my build thread so I don’t clog this one up.
MassHoe04
Western MA
What brand was it?
That is a bummer!
AC Delco is not always an option (based on when a guy needs it vs. when a guy can get it and/or cost), but would be preferred.
If I had to go non-AC Delco, I would certainly go Bosch or Delphi without thinking twice.
NAPA identifies Bosch as "actual OEM" on their site.
Certainly rock-solid choice, available same day and great pump for the money.
I know that Bosch was the OE supplier to Chrysler/Jeep for fuel pump assemblies on Jeep TJ Wranglers (00-06). The one I had lasted over 200k miles and 16 years. I trust them 100%. Delco and Bosch were not available locally when that pump died, so I went with a Delphi and was happy with that decision.
Delphi also good choice for replacement, if Bosch or Delco not available.
Scottydoggs
NJ
That sux. Still under warranty?
pretty sure it was a rock auto buy. no idea if they offer a warranty. might have been a reman too. no time for all that tho. got rain coming monday so ill likely be off work, so bright and early im headed to the shop across the street and let them do it. cant be driving the SS to work if i can avoid it.
RAMurphy
Bob
Military
S. Maryland
Oh man that really sucks. That is what concerned me when I replaced the fuel pump on my 2002 Tahoe. It had 290K miles on it and I changed it because of the number of miles on it. I did install a Delphi - hope it is not a dud.
Scottydoggs
NJ
last one i changed cause the level sensor died. pump worked fine. 130k on it now.
Nooj
I put these big boogers on, and Goodridge hoses (it’s been a two day affair… maybe three- I work slow). Had to shave the ridge a smidge to clear my rolling stock.
My driveway was sad when I scratched this one… :-( But that was before I shaved the ridge, so it got some touch up paint. Driveway is happier now.
Nooj
Scottydoggs
NJ
got rained out of work early, so i got the hoe dropped off at the shop. owner said hes also gonna check the crank sensor as they can get hot and cause stalling. the no fuel pressure deal leads me to the fuel pump tho.
side note. the camaro is damn sketchy to drive in the rain. it never see's rain so im super inexperienced at driving it and its ass end sliding around with no gas really given in the rain. ***** slid ******* one turn with the tc on, i was like you have to be kidding me lmao.
worleytrev93
