Mudsport96
Did an oil change and drained the catch can. Found it is cheaper to get filters from the dealership than O'Reilly now. That is a little disturbing.
Pcm? Haven't really heard of one goung bad other than bricking one during a tune that goes wrong.Took a long ride today, and it didn't run that great. Took the mechanic's advice and cleaned the maf, and also cleaned the air filter--for now. I'm probably gonna buy a cheapie but figured I try and clean it 1st. Couldn't even see through the filter it was so dirty. Gf is driving it tomorrow, so I guess we'll see if it helped. Pretty sure it'll need a pcm too.
Just my luck I guess. I can't tell you how many times in my life I've heard--"I've never seen that happen before"--LOTS!!Pcm? Haven't really heard of one goung bad other than bricking one during a tune that goes wrong.
Well I just tried jumping that switch connector and got the compressor to come on after it tried 3 times. And it did not sound good. So it looks like I’ll be replacing it. Time to put a parts order in. @clandr1 were you the one that said you ended up with metal fragments from the compressor in your system? I’m hoping mine doesn’t but when it turned on just now it sounded like something was clunking. Hoping this doesn’t turn into a nightmare.You could try jumping the plug for the low side switch with a paperclip or something similar to see if it forces the A/C clutch to engage. I probably should have mentioned this sooner... Skip to about 1:30 in the video.
Celebratory ABS and Brake warning lights and all!Hit a milestone today.View attachment 378010
Mr Big shot with 3/4 tank of gas.Hit a milestone today.View attachment 378010
It was me and what a PITA it was to flush and clean. You'll know pretty quickly when you open up the system especially at the orifice tube.Well I just tried jumping that switch connector and got the compressor to come on after it tried 3 times. And it did not sound good. So it looks like I’ll be replacing it. Time to put a parts order in. @clandr1 were you the one that said you ended up with metal fragments from the compressor in your system? I’m hoping mine doesn’t but when it turned on just now it sounded like something was clunking. Hoping this doesn’t turn into a nightmare.
All right thanks. Fingers crossed. What symptoms did your compressor have? Did you know when the “catastrophic failure” happened?It was me and what a PITA it was to flush and clean. You'll know pretty quickly when you open up the system especially at the orifice tube.
My understanding is that when something goes that sideways in the a/c system, it’s pretty well expected that all these parts need to be replaced. Problem is.. what if any little remnants end up in that new compressor you’re installing..?Well I just tried jumping that switch connector and got the compressor to come on after it tried 3 times. And it did not sound good. So it looks like I’ll be replacing it. Time to put a parts order in. @clandr1 were you the one that said you ended up with metal fragments from the compressor in your system? I’m hoping mine doesn’t but when it turned on just now it sounded like something was clunking. Hoping this doesn’t turn into a nightmare.
Well it’s like @RAMurphy said, if there’s metal fragments in the system I’ll know when I look at the orifice tube. And if so, I’ll have to flush the crap out. I’ll cross that bridge if and when I get there. Hopefully I won’t need to.My understanding is that when something goes that sideways in the a/c system, it’s pretty well expected that all these parts need to be replaced. Problem is.. what if any little remnants end up in that new compressor you’re installing..?![]()
Sorry for the delayed response, family life got in the way. So symptons: for about 3-4 months I would get a rattling/vibration when the compressor clutch engaged. Then I lost a belt. Did a little research, so I replaced the tensioner. Didn't help. It was still cooling, just not as well. So I continued to troubleshooting. Then I lost another belt. It was middle of the summer, so I replaced it, and ran it at idle as I watched. Everytime the clutched engaged there was a slight metallic grinding noise and the belt would vibrate and most likely slip. Lived with it for another month and noticed cooling significantly dropped off when at idle. Two weeks later it essentially blew up internally when at a light. The freon all leaked out right there. It looked like my engine compartment caught fire. Hope that helped, BobWell it’s like @RAMurphy said, if there’s metal fragments in the system I’ll know when I look at the orifice tube. And if so, I’ll have to flush the crap out. I’ll cross that bridge if and when I get there. Hopefully I won’t need to.
Mark, I also ended up buying a o-ring/seal kit. Not that expensive and I was glad to have it.
