Swapped out my lower driver seat cushion with a direct replacement. Man my ass thanks me!!
I swapped the seat back foams too from pass side to driver's side.
Bathed the engine bay in carb cleaner hoping to find a leak. Did not. The longer it sits the worse it starts; got service stabilitrack flashing engine light today when starting and pegging3k to keep running. Went away after running smoothly.
Maybe pre02 cats are clogged? I doubt it, because raw fuel dumps out the exhaust when it's stumbling on start. Fouled plugs then?
Parts trickle in over the next few days. Headers today, injectors tomorrow. Already have plugs/wires. Losing faith over here. Might hook up my sxs and atv on the trailer and drive to a dealership and give it all away for a car with a warranty lol (that's mostly a joke)
I checked a few days back on a cheap obd2 code reader and st was trying to lean it out to the point of -4ish iirc.What does the fuel pressure look like at the rail, KOEO? What do the fuel trims look like?
Koeo Fp 52.x and drops to 49.x after 2 mins an likely continues to an extent. Idle fp steady 43.x
If I shut off and reprime the system fp is at 57 and climbs to 72+ over time w koeo
Most sensor readings look normal to me, save for the stft's being a bit jank and the eth% at 52.9. Maf is clean as a whistle.
No flood clear used to start, but maybe it needs it
Also sorry for sullying up thus thread. I know it isn't the right place. I honestly thought this would clear up and be a non-issue, as this is not the first dieselgate in this family, but it is definitely taking the longest to repair. Again, apologies.
Yeah just good old 93. My stft's are in the negatives almost always at idle: from -1.xx thru -4.96% or thereabouts.If you're not running more than E10, but the PCM thinks you are, it's going to be adding fuel since it thinks it needs more. Your STFTs would be way high to the positive side, then, and that will cause over-fueling and it'll run like poo. If on normal (low ethanol) fuel, then the alcohol percentage needs to be reset with something like a Tech 2.
*Shrugs
Ima drive tf out of it and see what happens...
Installed a set of Husky mud flaps. It will be nice not to have slush mounds and mud splatter built up on the fenders/rockers/running boards/exhaust tips.
View attachment 376310View attachment 376311
I fixed some scratches on my passenger seat. These were probably caused by some web gear or suspenders during hunting season. I used an autoleatherdye.com kit. So far I only did that center panel where the scratches were as a test. You have to put the dye on THIN to prevent plugging up the holes. I put on two THIN coats. It came out pretty well.
View attachment 376317View attachment 376318View attachment 376319
*Shrugs
Sometimes touching the negative and positive battery cables together (after both disconnected from battery of course) will discharge any saved small voltagesSounds like a tech2 is needed, reset all things.
Try the battery trick, leave it disconnected for like 10min.
I like to cycle the ignition key while it's disconnected, thinking capacitors might drain faster.
My sister put either diesel or contaminated fuel into her 85 Audi 5000 when i was a kid.
It took out her headgasket and still never ran right.
We ended up selling it cheap.
Guy that bought it told us replacing the fuel injectors did the trick and complimented us on the great job we did with the cylinder head refurbishment.
That Audi has mechanical fuel injection, I'm not sure how far they needed to go with the replacement.
I also wonder about your upstream 02 sensors.
Diesel could contaminate them, no?
Remove and clean them with carb cleaner?
I would only care about the upstream ones...
I avoid cleaning/staining the deck at all costs. Now every time I'm out by the pool or playing guitar out there I stare at the planks and think how it really needs to be stained and hope it gets done while I'm gone.Since we got up extra early to take the dog to the vet, wife and I decided we should clean the lower deck. Then to avoid that task I...
