Yukon drives like a death trap after 4" lift.
cbenten83
2015 Yukon 4x4, Installed a 4" BDS and 35's on stock wheels a couple of years ago, and ever since then it drives terrible. Feels like it oversteers really bad, it's all over the freeway at 70mph. Could this be an install issue from the get go? or maybe a sway bar issue? Everyone that has driven the car thinks something is wrong with it.
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally help you with your question; however, other members on this Forum that are much more knowledgeable than me will chime in.
THarber
Anytime you go up with lift or tire size, any existing problem is magnified. I would check the alignment, then inspect the center link, idler arm and tie rods. Or reverse that in case you need to replace parts. Its an easy replacement of everything. Also take a good look at the front hubs and ball joints.
C
cbenten83
Thanks for the reply, alignment is something i have not checked just because it drives straight but there could be something there. I took it to a front end shop and had em check everything. Needed one ball joint but didnt change anything. it does feel like bad oversteer so maybe an alighnment will help.
It started the first day the lift was installed and has stayed the same ever since.
tom3
Alignment for sure, and have them take a second look at the steering links. That lift really changes the geometry of the linkage. Any looseness is magnified quite a bit.
There's more to an alignment than just driving straight. I bet you don't have enough positive caster or, worse, zero or negative caster. That'll make sensitive, twitchy steering. Find a large, empty lot for this: At a slow speed, maybe 5-10 MPH, if you turn the wheel and let go, does the wheel naturally return to center? Back straight up and test the steering left to right- is it still as sensitive?
91RS
GA
What kind of lift is it? If it is a spacer lift (spacer(s) on the top and/or bottom of the struts) reusing all the stock control arms and knuckles, that will definitely drive terrible because the ball joint angles are all trashed and it'll have awful bump steer. You really can't go more than 1" up or down without doing something to maintain angles if you still want it to drive nice. I'm sure this statement will make someone angry and want to argue but anyone who disagrees usually just doesn't notice how bad it drives compared to stock (and you may want to be thankful for that because being oblivious is a lot cheaper).
Who installed the kit?
C
cbenten83
Ok thanks ill try that, sounds like an alignment check is my next to do.
C
cbenten83
It's a BDS 4", just like their 6" but 4. Not a spacer lift im aware of that being no good.
Speardog
