Sparksalot
They’re going to replace it if we do the deal.What’s with the broken windshields down there? Must be a Texas thing.![]()
That’s the typical thingMine cracked on my way back from Havasu in 116F summer, not a cloud in sight.
It was perfectly fine, pulled into a gas station(parked in the shade) for some cold drinks, came out like 5 mins later, had a crack...assuming it started from a chip I couldn't see, right on the edge of the windshield.
it was the fan motor going bad, the connector to the fan was melting on both sides, resistor looked good, ran out to the junkyard and got a motor and connector, pulled the pins out and put them in the new connector, put the motor in good to go. $39now onto the wifes 05 ac fan quit blowing yesterday in the middle of a heat wave, I am pretty sure it's the resistor (again) or the wires melted, no fan at any speed
One of the things I noticed as a snowbelt traveler, when I get down south l, is you guys have way more debris on the shoulders and along the centers and the medians. Up here they have to plow snow and usually the snow acts like a sweeping compound and sweeps all that debris way off onto the shoulder and way into the median so we don’t have as much debris to kick up into windshields.
Mine had a 1"(=2" at the wheel) spacer on the bottom of the strut, and if you wanted 2.5", then you could add the 1/4" spacer on top of the strut.Well I got the strut installed, and I didn't die or create any holes in the ceiling.
Singing "I'm doing some sketch shit" song I made up as I worked.
I got to the 2in lift puck thing that I planned to install on the top of the strut.
Then here I am looking at how the strut sits in there.
I notice this center part of the strut that seems to line up nicely with this part on the frame.
Almost like they designed it to be supported/centered....
Yeah I don't think I'm going to level the tahoe that way now...
I'm glad I looked before i went ahead and started trimming bolts off of the very expensive retaining plates.
I like that idea better, that 1in plate at the top won't work for me.
It needs some sort of centering for the top of the strut imo.
www.truxxx.com
He was doing that with the worn parts-should be back to buck thirty five on two wheels, in the snow, and in traffic!Now you can take them 120+ mph turns better
mmm, kind of risky in Traffic I only hit those numbers on a runway unless it's a 8 lane with plenty of room, takes over a mile to get up in that rangeHe was doing that with the worn parts-should be back to buck thirty five on two wheels, in the snow, and in traffic!
On the factory driveshaft?mmm, kind of risky in Traffic I only hit those numbers on a runway unless it's a 8 lane with plenty of room, takes over a mile to get up in that range
many many many times and many miles yesOn the factory driveshaft?
This is a good question, many seem to let go around/above 110mph from what 8ve heard. Not sure what drive shaft speed that'd be.What is the factory driveshaft critical speed (driveshaft rpm)?
Interesting...many many many times and many miles yes
