Sparksalot
Bastrop County, Texas
Mine cracked on my way back from Havasu in 116F summer, not a cloud in sight.
It was perfectly fine, pulled into a gas station(parked in the shade) for some cold drinks, came out like 5 mins later, had a crack...assuming it started from a chip I couldn't see, right on the edge of the windshield.
That’s the typical thing
now onto the wifes 05 ac fan quit blowing yesterday in the middle of a heat wave, I am pretty sure it's the resistor (again) or the wires melted, no fan at any speed
it was the fan motor going bad, the connector to the fan was melting on both sides, resistor looked good, ran out to the junkyard and got a motor and connector, pulled the pins out and put them in the new connector, put the motor in good to go. $39
Just Fishing
Can't fix stupid
Utah
Well I got the strut installed, and I didn't die or create any holes in the ceiling.
:cool:
Singing "I'm doing some sketch shit" song I made up as I worked. :emotions33:
I got to the 2in lift puck thing that I planned to install on the top of the strut.
Then here I am looking at how the strut sits in there.
I notice this center part of the strut that seems to line up nicely with this part on the frame.
Almost like they designed it to be supported/centered....
:banghead:
Yeah I don't think I'm going to level the tahoe that way now...
I'm glad I looked before i went ahead and started trimming bolts off of the very expensive retaining plates.
One of the things I noticed as a snowbelt traveler, when I get down south l, is you guys have way more debris on the shoulders and along the centers and the medians. Up here they have to plow snow and usually the snow acts like a sweeping compound and sweeps all that debris way off onto the shoulder and way into the median so we don’t have as much debris to kick up into windshields.
Yeah, we trashy.
RooTBeeRthe1st
:cool:
:banghead:
Mine had a 1"(=2" at the wheel) spacer on the bottom of the strut, and if you wanted 2.5", then you could add the 1/4" spacer on top of the strut.
Just Fishing
Can't fix stupid
Utah
I like that idea better, that 1in plate at the top won't work for me.
It needs some sort of centering for the top of the strut imo.
RooTBeeRthe1st
This is the kit I bought, but I only paid like $100 for it...
Also, when I did the King coil-over swap, I pulled it all off, been sitting in a box since. If anyone wants it, just needs new nuts/bolts.
He was doing that with the worn parts-should be back to buck thirty five on two wheels, in the snow, and in traffic!
mmm, kind of risky in Traffic I only hit those numbers on a runway unless it's a 8 lane with plenty of room, takes over a mile to get up in that range
St. Louis
Engine rpm divided by trans gear ratio to determine driveshaft rpm.
3000rpm in 6th (0.67)= 4477 driveshaft rpm
I did it even more in my 00 blasted that thing all over the western half of the country, from north to south, california, oregon, washington, utah, montana, idaho, wyoming, nevada, arizona, new mexico, texas, kansas
aflumb
Las Vegas
Been a pretty expensive week for the ol Wifey wagon
Replaced the following:
- Front Driver door panel (got tired of the broken grab handle)
- brake pads, rotors, front brake lines
- Flushed the brake fluid
- rear wheel bearings
- right rear wheel speed sensor
- right rear brake caliper
- rear diff fluid
Now thinking about replacing all the front suspension components
Cant really complain when the Truck hasn't cost us nothing in over 5 years other than wear items/self inflicted issues
Hodmjstone
