Running sweet after AFM delete
Ivanhoe
Canada
Hello folks,
I finally got around to fixing my 5.3 2012 tahoe and got rid of afm, it's now running smooth and no faults.
I used a kit from Texas speed along with oil pump and timing chain for long term piece of mind.
I had help from retired mechanic relative who supervised my spannering. There were a few issues such as a nest for some creature under the intake. I had some unexpected repairs to make once we started digging around underneath.
I decided if I was going in deep I may as well do the chain and oil pump. I was tempted to get some more power but kept it stock to avoid dramas.
I kept the VVT as I used a L96 cam ( from a 6.0) which works without DOD.
Dropped the diff out as a seal had gone which made oil pan removal easier. I purchased an LS Oil Pump Pickup Girdle for the oil pump which worked really well and used 2 bolts rather than one that gm had.
Camshaft was well chewed and roller wheel was scored but not sure what was wrong with it and it appeared ok.
If I had to do it again, I would take engine out for speed and ease of access. It was done on axle stands in a small garage which not ideal but can be done. 20220520_155129.jpg20220521_113123.jpg
Geotrash
Dave
Richmond, VA
Congrats on a job well done! That failure mode on the cam lobe is interesting. Almost looks like the roller on the lifter was periodically binding and scored a groove in the cam in the process. Doesn't look like an AFM failure so much as it does a plain old lifter failure. Was this on an AFM cylinder?
I
Ivanhoe
Canada
Yes it was on #4 cylinder. On the head picture you can see the head which is cleaner than the rest.
I
Ivanhoe
Canada
All lifter trays replaced and she makes good oil pressure?
Yes, all GM oem trays, it was turned over a couple of times with injectors disconnected to get oil through the system. Fired up and instant good pressure once injector leads in. New exhaust manifold bolts as well, one was snapped off ( back one of course) before I even started. Managed to get that out with ratchet grip tool thing my relative had. The oil pipe Girdle I used made sure that oil pipe won't come loose with the new o ring.
I
Ivanhoe
Canada
About how long did it take to swap?
Friday afternoon to Sunday night...but that was with meal breaks and trips to autoshop etc. Could be done in 2 days if you had everything ready at hand, we found some issues that required more parts so dealt with those which took time. Right angled impact wrenches are a lifesaver along with regular ones
Hello folks,
If I had to do it again, I would take engine out for speed and ease of access. It was done on axle stands in a small garage which not ideal but can be done.View attachment 371090View attachment 371094
+1 for pulling the engine. Just a few more bolts lets you access the rear to replace those seals and easy engine mount replacement/upgrade if those weren't done already.
I
Ivanhoe
Canada
If you have any questions I can help with just ask..having an old mechanic to supervise helped but it was a lot newer than what he used to work on .if you have some mechanical knowledge and ability it can be done. Added some more pics
Sorry for lack of after pictures ...I was using phone to watch nhl playoffs.
Replaced the tensioner with an old style ls chain damper which left the chain slightly slack but the old one wasn't doing anything as the spring was gone .
Thinking I should have possibly changed sprockets, i have used a new VVT bolt on new cam.
Oil pan was taken apart as it had a thick layer of gunk ... 260000 kms (160000 miles) worth with whatever burnt oil from afm.
New cam thrust plate and bolts put on as well ( missing from.list )
All pushrods etc covered with liberal amount of assembly lube (permatex ultra slick) so there would be some lubrication.
robgreg75
268K miles on my 2010 with the AFM active and I even programmed it with my HP tuners to run as a 4cyl more changing the parameters and increasing the power in 4cyl mode and also change the shifting to higher speed per gear to run as a 4cyl more. Use Mobil 1 5-30 oil and it doesn't even need oil added between changes it might use 1/2 quart by the time the DIC says 25% life left, which is usually when I change it.
I
Ivanhoe
Canada
Update
500km done and still running fine and oil change done. Looked pretty dark for oil that was a week old, will cut filter open to see if any bits are in there. New filter and synthetic oil ( Mobil1) to keep things rolling smooth
tssetmr
I didn’t see any mention tuning having been done. If you know of a tuner in your area that is good with LS powertrains you might be surprised as to what can be pulled out of it.
Last week I too did a DOD/AFM delete on a 2012 suburban. Used a Gen 3 cam though. Went old school for reliability. Custom tune afterwards and holy cow! It barks the tires nicely at the 1-2 shift! I too had problems with cylinder 4 lifters. Could not for the life of me figure it out. I even worked with experts in the LS platform. Nobody could figure it out. So I did the logical thing and deleted it all. Glad to hear yours is running great now too!
Chickensandwich
I just got a 2018 PPV. I fear lifter failure. I had a 2008 suburban and a 2015 Tahoe, both had the SAME lifter failure. The suburban was civilian, the 2015 was a PPV. GM has an issue with their 5.3l engines and refuse to acknowledge it. I hope this issue doesn’t show its ugly head in this truck, or I’m swearing off GM for life.
wjburken
Eastern Iowa
Hello folks,
Good job!
I had a similar cam/lifter failure on our 2007 Denali with the 6.2 (NON-AFM). The #5 intake roller looks to have locked up and scrubbed through the hard candy shell of the lobe into the soft nuggetty center.
I too did this in the garage with the motor in place.
I
Ivanhoe
Canada
Got AFM programmed out prior to strip down, there's a local GM specialist shop who recommended it as I could start up etc when built. I should probably take it back and fine tuned.
I
Ivanhoe
Canada
I got to 260000kms (160000 miles) before it appeared, PPV are usually well maintained despite the miles/hours run. This tahoe had 200000km when I bought it so I don't know how well it was maintained. I make sure now when it goes through oil changes its synthetic (more cost) to help preserve it
Chickensandwich
My last oil change with my fire was $75! I told them I only want the oil changed, not the entire engine! In this current world, I think it’s cheaper to swap the engine than go to synthetic oil changes.
bsmith901
Hi OP, I appreciate your post of your DOD delete. Hows the idle quality and low end torque with the L96 cam? I’m planning on a DOD delete for my 2007 Yukon XL 5.3 w/flex fuel and saw reference to that cam for keeping VVT and maybe for a slight performance increase. Also did you get your heads worked and/or upgrade the valve springs. Same with timing gear & chain. With 180k miles I’m thinking of doing that as well while they are off. It seems like these engines last forever other that the DOD components so I don’t want to over do things if not necessary.
CrackerJack135
