2004 6.0 NV4500 Tahoe
pwtr02ss
Tennessee
The younglings in my welding class said the single 3” cutout ain’t loud enough. Pushing me to do dual 3” or a single 4”. If you were being pressured by ***** teenagers what would you do? Remember I need to cut and redo it anyway and I do have a 4” on the shelf
Is it loud enough for you? If not, throw that 4" in there. That extra inch can make all the difference....
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
What you don't really hear is the cam chop, I need to drop the idle down to 650 or so instead of 800-850 W/AC on and see if it chops more but I think it also has to do with the single exit instead of sperate exits per side. Of course this cam doesn't have any overlap either which means less chop but idk I feel like its chopped more in the past.
I probably won't do anything other than turn the 3" around and work on the v band leaks. Just thought it was funny that a cutout wasnt loud enough for the younglings, I guess they want open header these days.
randeez
south florida
Letting the youths down
pwtr02ss
Tennessee
My camaro is single and the effer has plenty of chop.
Its probably the idle being so high. Adding 100 rpm to my avalanche made it go from a slight "chop" to now it just sounds like it has a miss....But I think it smoother, even if it does sound like its missing here and there.
3" is plenty...or so I've heard
randeez
south florida
yep, if you cant get it done with 3, no amount extra is gonna help
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I definitely think idle has a lot to do with it, I'll mess with that later today and see what happens.
Then I guess no amount is gonna get it done.
Straight pipes, 6" front lift and 4" rear drop. How far will you go to impress the toddlers?
The best part of those setups is the loss of usable fuel tank space. Probably starts sputtering after a half tank when its up on its end like that.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
This is getting ridiculous, ac worked great for a week or two then suddenly quit completely. Today I resealed the front cover and tightened all the oil pan bolts which were very loose despite being torqued to spec. Checked AC and it had no pressure at all. Quick look at the line that’s broken 3 times now and yep, same spot it’s leaking out of. WTF!!!!!!
I’m beyond pissed off ac problems are the worst and this is getting to be too much.
... Probably starts sputtering after a half tank when its up on its end like that.
Which sounds really cool through straight pipes. It also gives them a reason to make more frequent fuel station stops so they can cry for your attention with the trap and autotune beeping from the PA horns mounted to their frames.
randeez
south florida
shine a black light under my hood and you see all kinds of leaks :oops:
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I like dat trap shit
But is it AC coolant?
I think I’m gonna weld this line around the base where it’s press fit and give it another shot they are expensive lines.
Durobans
