Lifted/Leveled 2021 - Postem Up
DWSmoot
DWSmoot
Charleston, SC
they had to pull felt back behind tire and trim some plastic in front I posted pictures of the trimming
Jgrimberg1979
Post up your lifted or leveled 2021 with setup details.
I’ll start:
1” front level strut extension nothing in rear.
Wheels: 22”x9” +24 offset
Tires: 285/50r22 Nitto Ridge Grapplers
Nice ! Love it bro. Good choice my man and thanks
woils you happen to have any part part number and the site you used. That a favor but if not o can figure it out. Love that truck. Makes me wish I didn’t get black high country!
how does it ride. A little rougher, not too noticeable, or much different truck?
DWSmoot
DWSmoot
Charleston, SC
I have changed up the stance since first posting. What are you looking for the 1” front level kit I initially posted or the 2” Rough Country level I am running now.
Jgrimberg1979
Wihatever setup that you have shown in the picture
Jgrimberg1979
RC also says the 2/1 lift they have for suburbans/tahoes will not fit a yukon or a z71 but myself and others on here have found that to be incorrect as that kit indeed fits both yukons and z71 models
you have air ride correct? Links would be great for the parts that worked if you have air suspension
Morales1995
I thought I’d post mine up since I’ve asked a million questions on here. See if I could help someone else with questions. I ended up just doing the lower strut spacer (said it was 1.5”) with 18x9 method 316’s and 285/70/18 Nitto Ridge Grapplers. Zero rubbing but I’m very very close to the liners…I think I pushed the limits and barely got away with it.
Okay now this is what I got in mind… can you please give me some more information on ride change with the 18s the speedometer change and over all what you think? The 20s Are just meh to me and the tires look so skinny… but I don’t wanna compromise it too bad.
olyelr
Elk Rapids, MI
As long as you go with the same overall size tire, it dosnt matter what wheel size u have…the speedo wont change. Also, you can get wide tires for the 20’s…
Jgrimberg1979
Can someone confirm that nitto ridge grapplers 305-40-22 will work on a high country suburban, and are there any negatives or a better option
olyelr
Elk Rapids, MI
Do they even make that size? Im sure they have a 305/45/22, which is closer to factory size. A 40 series would be too shorter than factory.
I put 305/45/22 toyo at3’s on my wifes high country and they fit fine.
Jgrimberg1979
I’m sorry typo meant 45
Jgrimberg1979
Do you have any pictures? How’s it ride
Morales1995
Wide tires isn’t my thing I prefer more or less flush to the fenders but I do like a thicker sidewall but from what I’m reading that can’t be achieved with 20s
olyelr
Elk Rapids, MI
Rides great.
olyelr
Elk Rapids, MI
Well the only way to get a thicker side wall is to downsize the wheel or upsize the tire.
Charlie21ny
