Tonyrodz's Tahoe Build Thread
Its a GM fluid so last I checked, dealer or amazon.
Thank you. At this point I'm trying to figure out which one I'd prefer to be bad--tc or rearend. Whichever is easier or cheaper!
Offhand, do you know how much it'll take? Amazon is $10.90 a qt. Good price?
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Usually the spider gears will let go before the ring and pinion. You'll know if it's a spider because it will drive fine in certain positions. Once you start to turn a little and make the spiders start to rotate it will hit a dead spot and start skipping again.
pwtr02ss
Tennessee
@Fless said 2 quarts should have you covered. I can't remember exactly but that sounds right. Yes, $11 a quart is cheap. I believe I paid over $20 a quart at the dealer (before Amazon)
I think that's what might be happening.
Snowbound
Jim
Chicagoland (Lockport)
I’d rather have it be the transfer case than the diff. I hate setting up differentials. It’s time consuming and tedious. I’m always second guessing myself although I’ve only ever had one fail after gear swap and that was on drag car but in that instance the plug welds broke too and the center section turned straight up, ripped the driveshaft in 3 pieces shot out the back, broke the yoke off the diff and split transmission case right up the middle. All happened coming out of burnout box when I let off the line lock.
Transfer case is a fairly easy rebuild. Hardest part is taking it out but then again, you only have one driveshaft to contend with. Lol. Hope it’s an easy fix for ya either way. If this stuff was easy and cheap, everyone would be doing it.
If it's the rear, I'll just swap the complete rear. No rebuilds.
Got my thermostat and another abs sensor in.
89Suburban
SE PA
I'm glad you did. I wanted to pay my son to do it--he said he didn't want to spend all day doing it. Rusted brake lines would def take some time.
Don't you have coil springs in the rear??? U-Bolts wat??
I’m thinking he was talking about the u-joint straps which should be replaced unless they go back on the same u-joint caps (in which case they need to be marked when removing so they go back on in the same exact orientation).
Ossipeelake
