StrkAliteN
How would I know or find out if my 2007 Yukon has a factory tow package?
I am researching brake controllers and I guess this is needed info.
I know enough about towing a trailer to be dangerous.
I have my VIN 1gkfk13047j283176
of course I have a tow hitch and wiring harness plug on the bumper.
What is a tow package ? and do I or do I not have it already on my Yukon ??
thanks in advance.
There is a trailer icon and button on the end of the drive selector arm on the steering console. When the button at the end is depressed a trailer icon appears on the instrument panel. I honestly have no clue what that feature even is or does. Have never towed anything with this rig. I am installing a brake controller and need this info as I am searching on etrailer for controller info - tutorials.
thanks in advance
RooTBeeRthe1st
thanks in advance.
thanks in advance
RPO codes
Z82 - TRAILERING EQUIPMENT
K5L - HEAVY DUTY TRAILERING PACKAGE
Thats the tow/haul button.
just a different trans tune. holds the trans in gear longer, lets the engine rev higher even with light throttle, keeps it out of 6th until like 80mph.
StrkAliteN
RPO codes
Yea neither of those 2 codes are listed on the glove box dealio sticker. So I would think it is safe to assume my Yukon does NOT have a factory tow package.
So that stated, chances are slim it has an oversized xmission cooler or anything similar I am guessing.
RooTBeeRthe1st
VR4 - WEIGHT DISTRIB. PLATFORM HITCH
K5L - HEAVY DUTY TRAILERING PACKAGE: * ENGINE OIL COOLING SYSTEM * TRANSMISSION OIL COOLER
KC4 - ENGINE OIL COOLING SYSTEM
KNP - HD AUX TRANS. COOLING SYSTEM
Don't worry about that trans cooler... The auxiliary OEM trans cooler is a joke.
If you're worried about trans temps, get one of the aftermarket units and put it in line in the system.
And if you're really worried about heat, definitely upgrade the radiator.
StrkAliteN
VR4 is the only code on my sheet of the 4 codes you listed
Thanks for the help
justchecking
Military
SW Ohio
They offered me some money back to compensate for my troubles. In the end I was happy. The seat still lacks the power to raise my 235 lbs but I need it all the way down and it only would need to go up if my wife drives. She has been instructed to press the memory button, wait for the seat to move and then get in. I think part of it is due to my not getting the large gear on perfectly true.
Same here, I need it all the way down. Anybody else will have to raise it up standing outside. Now my gear wouldn't quite slide on so I had to file the shaft a little bit. After the JB weld set up i spun the shaft and the gear was straight. When I popped the gear into the housing there was a bit for and aft play so not too tight. Then when I put in the worm gear and popped the top of the housing on it seemed to go on with no issues. Had I known I could have checked a couple more things, maybe some warm day I will. I will also contact Gruven.
drastevenson
So over the weekend, I installed my lLED head light bulbs, LED Fog light bulbs, full length 3rd brake light, 4th gen style tail lights, front sway bar end links and front brakes. I'll be working on the rear on e the weather gets a bit better here in Chicago
Can you link where you got the Tail lights?
I pulled this parking brake switch out and vacuumed up all nice and clean under there. It's a 7mm socket for the bolt. This style switch you can pop out the brass contacts and clean them up. There was some kind of a greasy varnish on them. I used my bench grinder wire wheel on slow speed and light pressure to clean the contacts up. Works like a charm now. Didn't get any after pics, temps are dropping here and I was in a rush. There is a locating pin sticking out of the back of the switch to help clock it into the correct position when reinstalling.
I've fixed those by holding the release handle so the pedal didn't lock down and repeatedly cycling the pedal down and up. After a few cycles, you'll see the light working again.
thanks in advance.
thanks in advance
Your tow rating is 6,700 pounds as is (GCWR 13,000), I reckon that you have 3.73 gears, RPO GT4. GT5 is 4.10 gears and tow rating would be 7,700 pounds (14,000 GCWR). If memory serves, the 4.10s would include KC4 and KNP. Curiously, the 2007 Brochure lists higher tow ratings (7200/8200) than the 2007 Electronic Owner's Manual. Data comes from the Electronic Owner's Manual.
RooTBeeRthe1st
I don't feel like looking up my build sheet again, but I know mine has the 3.42s and 7300 lb rating
StrkAliteN
RPO codes
I can see how that selected option would enhance driving / towing around town.
Once I am on open freeway driving hundreds of miles on flat interstate, would it be a good or bad idea to turn off the trailering button and just use normal transmission for greater fuel economy ?
Geotrash
Dave
Richmond, VA
No. It will keep hunting in/out of 4-5-6. I run it in tow/haul mode when towing our camper and limit it to 5th. Makes no difference in fuel economy but it’s a lot easier on the transmission.
justchecking
Military
SW Ohio
The difference in additional heat (I replaced cushion and cover) coming out of that seat now is remarkable. I wish I had the old cushion to tear apart but the trash man already took it.
drove from here to Disneyland which is about 370 miles at around 80mph and then back home another 370 at around 85mph
left with a 11.9 mpg and ended up with a 12.5 mpg upon return. it's difficult to get anything better out of it, it is what it is
enigmaspeed27
