St. Louis
How about "ease the seat back" ?
You could do that too, but then you gotta adjust the mirrors and the steering wheel is further away, lol
BUT if your pedals are already all the way forward, or you don't have adjustable pedals, then that'll work.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Now that that topic has been brought up, is there a way to add adjustable pedals to say my '07 Tahoe that doesn't have them? I think that's the only thing I liked about that F-150 I had to borrow. Or a manual way of moving them somehow? I like my seat back far but would like to move the pedals back too.
St. Louis
I have no clue
Looks like it was an option on the SLT trim. Curious if that is a doable mod. @Doubeleive @iamdub @ anyboddy else - any thoughts?
" is there a way to add adjustable pedals to say my '07 Tahoe that doesn't have them?"
You'd have to also mod the BCM to make it work unless you found a redneck way to do it with your own Pedal motor and a rocker switch :roflbow:
maybe if you added the pedals, all the needed wiring, buttons and memory module, not sure if the bcm would need to be flashed or not
maybe the pedals could be done separate otherwise the memory function moves the steering wheel, mirrors, seat and pedals
Just Fishing
Can't fix stupid
Utah
Both my hoemare and the Buick have them
Wife is short.
We don't touch the pedal adjustments, just the seat.
Now I'm thinking I should give it a go in her car.
Memory too, so if i happen to find a better spot... :boobs:
I am curious if you happen to have a plug tucked up somewhere for the adjustable pedal...
Tozan
Overlander
Beauregard, Louisiana
I replaced my two batteries today and decided to install a Spartan Power smart dual battery isolator in the circuit. The second battery is hooked up to my winch and power distribution point it feeds refrigerator, interior lights and other camping accessories.
The isolator disconnects the batteries when voltage is below 13 volts and automatically re-connects above that. So, they are both connected when charged by any source like the alternator, battery charger or solar panel.
Next project I am going to install a start relay so, I can jump off the primary battery with the secondary battery from inside.
I also re-installed my 270 degree awning today I am getting ready for a camping/hunting trip next week in Bagdad.
I also started doing some planning for installing a couple solar panels on the roof rack.
Sobro
Nashville
@Tozan I would like to see your parts list and a few pics of your battery setup. I didn't even know about 270 degree awnings. They look like a good car camping solution.
If you don't want memory I see no reason why you couldn't retrofit power pedals fairly easily. And I'm not seeing any threads on repairing them so the pedal motor system has to be better than the stupid power folding mirrors, so junkyard shopping should work.
pwtr02ss
Tennessee
Speaking of members we haven't seen in a while... He showed up for a week or two, changed his name and left again. @PG01
Its been over a year since he replied to a text message from me (12/30/2020 to be exact). I've messaged him a few times here and there since. Message shows delivered...IDK what happened to the guy. He took a bit of a break due but he eventually texted back. I wonder about him often.
filled up the washer fluid with bug juice, brake flush, new plugs & wires, m1 oil change.
might be heading out for another road trip in a few days kids are out of school for 2 weeks the district here does spring break early.
might take them to Disneyland & universal studios, depends on how much the darn tickets are it was ridiculous last time, probably more now.
probably head up to yellowstone in July and head down along the tetons and over to the grand canyon, maybe the northside this time, not sure how the highways run from that way gotta do a little research.
j_jerry79
