ivin74
05 NBS Nali
Htown, Texas
Questions for those who have Denalis/6.0/etc. with all 3 engine covers and catch cans :
I was going to install these engine covers today, but hit a snag - I mounted my catch can to the alternator bracket and that is right in the way of where that engine cover needs to go.
Where is the best place to mount the catch can, and more importantly how did you route the hoses underneath the cover?
It seems like there is a lot of stuff in the way that will prevent this thing from getting where it needs to be.
In taking these off at the junkyard, I also noticed that the passenger side cover puts a lot of stress on those heater core tees. I better buy 2 new ones just in case.
Thanks
I have my cc on the passenger side fender well
adventurenali92
Big Bear Lake, ca
Thanks
I have a 2006 Denali XL, with a 6.0, I have a catch can mounted to the alternator bracket, and the lines fit perfectly fine under the engine covers. Nothing in the way or crushed lines.
MassHoe04
Western MA
I don’t have the engine covers as you can see but my CC came with a bracket that attaches with one of the bolts for the brake booster. I tried to get a good pic but it’s a black bracket so it doesn’t show up good. You could make something similar. View attachment 361454
Very nice! Now, I see how you got your user profile name @Rocket Man !
I thought, that would be cool to have on mine. How much? Then, I looked it up.
Whoa! When I saw the supercharger was more than I paid for my rig, my dreams were crushed!
VERY cool, though! Nice build.
mattbta
Frisco, TX
Got my rack, vent caps and door handle back from paint to match. Installed all but the handle. Phone was crapping out and I lost daylight, so all you get are crappy pics. Will take more later.
Guess I'll have to get Escalade hatch/glass/third light now...:D
MassHoe04
Western MA
Front sway bar link broke. Threaded part up top lifted up, contacted the passenger front brake hose and caused total brake loss when the hose let go. Fortunately, it happened in the parking lot at work. I had just driven downtown to pick up lunches, with a lot of stop and go both ways. Replaced the link and the hose.
Of course, the bolt holding the retainer clip on the upper control arm snapped off clean on the first turn (ratchet... no impact even).
Tried to drill out and the drill bit snapped in the hole!!
McGyvered my own screw in a new hole next the old hole. Good enough for now!
The upper control arm will be a spring project. There is not much, if anything left of the poly bushing up top...
Here is yesterday's project.
Wow you were lucky. Hope your e brake was working.
MadDogDelpho
Texcellent
Very long time, no post. The motor went out in my driver’s seat a while back so I’m trying to swap in some inexpensive seats from an ‘03+ To my ‘02 but having difficulty figuring out the wiring. So I’ll be nice and close to my steering wheel until I get it figured out!
SnowDrifter
Sasquatch Country
Very nice. Is that electrical tape on your overflow hose?:eek:
Yes but not for a leak
Had some abrasion concerns against the top of the hood so I put a sacrificial layer on there
Strictly speaking it's self-fusing tape. Electrical tape would get nasty with under-hood heat and weathering
Edit: I'm looking at it and realizing that's probably what the loom is on there for. Mine just worked its way to the reservoir side and I never thought twice about it XD
adventurenali92
Big Bear Lake, ca
Holy cow! Ain’t seen you around in quite a bit! Lol
mountie
Gave her twiddly bits a good scrub
Nice... very clean..... I noticed your emissions decals on the radiator cover...They look new.
Mine are completely faded. Anyone know where to get them replaced????
Also, the braided cover is in the same location on my overflow hose. FYI
iddqd
San Francisco, Comifornia, USSA
The time has come to raise the rear bumper. I installed 1" body lift a while ago, but was slow with the bumper relocation. Today a re-welded the brackets and also cut off spare wheel carrier to raise it up higher, as there's now plenty of room up there. Thinking may be install the secondary fuel tank as well.
BadDaddy2003
