MADPINTO08
Put some LED in the lift gate appliqués Still up in the air if I’m going to stick with it or not… tapped into the 3rd brakelight
But that's the plastic one with hoses. Im looking for a stainless steel y pipe
I don't know of anyone that makes a stainless Y-pipe, at least not mass-produced. Dorman makes theirs out of aluminum:
CLICK> https://www.dormanproducts.com/p-91571-626-553.aspx <CLICK
Product Description​
Original equipment HVAC heater hose assemblies often fail due to cracks in the plastic Y-connector. This Dorman OE FIX replacement features an upgraded aluminum Y-connector to prevent similar failures in the future.
  • Upgraded material - this replacement engine heater hose assembly features aluminum Y-connectors for added durability
  • Application specific - designed to match the original fit and function of heater hoses on certain vehicle years, makes and models
  • Complete replacement - hoses come with necessary clamps for easy installation
  • Quality engineering - designed in the United States and backed by decades of automotive aftermarket experience
It's definitely aloominnyum:
Now, THIS part is plastic, but you'd remove it to slip the hose over your Grüven T fitting:
I replaced that hose, as well as the other 5/8" hose with (I think) Gates.
ASG-MikeS
