St. Louis
To go with that thought, what is the thing with the rubber gizmos on the oil and transmission cooler lines going into the radiator?
Dirty pair are thecopcar. Off road donchaknow. Clean ones are similar on theothertwin.
Rubber gizmos? Are you talking about the plastic covers that go over the spring clips that hold those lines in?
those are just protectors so the c clip under them can't be accidentally knocked off, just pull on them and they slide back on the tube
If you're good at welding and have the right equipment you can weld a bead around the pipe
That thought crossed my mind. But it's two small pipes under the cowl and next to the firewall. And they're aluminum. I have a spool gun for my MIG welder, but it's definitely not ideal for that.
The pipe is 1/2" ID (or OD?). I'm thinking of modifying a large pair of needle-nose pliers to crimp a bead into it.
RooTBeeRthe1st
Do with it? Limped home 500 miles from Big Bend with a burst upper tank on the radiator. A 2.5" rupture near the top, so the engine still had coolant the whole time.
First I had to limp 25 miles out of the desert to try and patch it with JB Weld. Worked decently, but I couldn't reach the entire rupture, so it seeped all the way back.
Cold Case, I'm about to call...
Do it. Can't go wrong with it. It really works so much better than stock too.
St. Louis
If you're talking about the stock hardlines that run to the rear heater core, they should have a barb already on them. That's how they stay in the factory quick connects.
St. Louis
Even better is installing them- just push then in until they click.
And if you have the tool, (Lisle makes a small cheap one) it's almost as easy to remove. Just an 1/8th turn of the tool and pull the tube out. No having to remove the spring clip with a pick and hoping it doesn't go flying somewhere never to be found!
This fitting type is called a Jiffy-tite fitting and is used on just about all makes/models of automobiles.
That's cool! I've never seen those before.
I rub a shop rag around the the fitting to snag the clip and capture it in the rag.
You don’t happen to know the Lisle part # for that tool do you? The connectors on the side of the trans are the ones I have trouble with and that tool would be nice.
ASG-MikeS
