Interior lights
bigblue
Beaumont TX
First off i have a 2007 ls 2wd. My interior lights will not come on when i open the door, neither will they come on when i press the unlock button on the key fob. They will come on manually if i turn them on individual, or i turn them on with the switch on the dash. Any idea's what has happend?
LTZboy
I know on mine you have to have the door open and hit the interior light switch below the interior light knob.
bigblue
bigblue
Beaumont TX
on mine it worked before, it just like stopped all the sudden, i know all the interior lights work because i can turn them on manually, it use to work when i pushed to unlock button on the key fob and or open the door.
ICON
Bellingham, WA
use the DLC button on the dash, then scroll and find the interior lights section.
bigblue
bigblue
Beaumont TX
i just went and tried, i didnt find anything saying interior lights. I seen exit lighting, approach lighting, chime volume, and a few other, i didnt see anything about interior lighting.
Modded
That Guy
Yeah dude ake sure that cucumber looking button/knob in between the fog light switch, and whatever switch is above it, is in the extended position, if the button is pushed in your lights will not come on.:Handshake:
bigblue
bigblue
Beaumont TX
so that little button has to be left out not pushed in for the interior lights to work when the door opens? if so that did not fix my issue because i just tried and it didnt fix the problem.
Modded
That Guy
Well after bringing it out makesure the knob is turned all the way to the right so the lights are not pretty much in the off position.
Also try the buttong above the knob, press it, then open your door and see if it works.
If not, close the door, press it again, and open the door again to see if it works.
ICON
Bellingham, WA
hmmmm wow well you got me stumped... ill go jump in mine and try to get a better idea.
Edit: Modded is right, it is the button above the Fog Light switch. The interior dimmer switch is sandwiched in between the Fog light and the Dome Light switches. With my doors open it will shut off the lights when pressed and vis versa. Hopefully that helps! :)
bigblue
bigblue
Beaumont TX
Thanks MODDED and ICON for the help, i got it figgured out it was that little button above the dimmer switch, hell i didnt even know that was a button..lol
CKendrick
