Engine Power Is Reduced - Ongoing Issue, Updates throughout thread.
Mighty Hd
Florida
Vehicle is a 2013 Tahoe LT Z71 with 90k. Max towing pkg, two speed transfer case (2hi, 4hi, 4low & auto 4wd).
Fuel pump failed and also the fuel pump control module. I swapped the fuel pump today and I’m waiting on the FPCM to arrive at the local dealer.
I checked the modules and noticed there are quite a number of codes on the transfer case module, however the 4wd works fine and shifts smoothly. All bi-directional tests, actuator test, etc passed.
Codes C0321 - Range actuator engagement control circuit short to battery..
C0379 - Front axle engagement system short to battery.
B0770 - 4wd auto range indicator control circuit short to battery
B0775 - 4wd high range indicator control circuit short to battery
B0780 - 4wd low range indicator control circuit short to battery
B0790 - Transfer case neutral range indicator control circuit short to battery
C0374 - General system performance temperature high
U0073 - Control Module communication BUS off invalid data
Fuel pump module now only has:’P0606 indicating an internal failure on the module.
I cleaned the ground wires to the engine block from the battery. Ground strap on driver side head to the firewall Ground wires on the frame mount under the driver door Ground wires on the driver side last body mount.
Transfer case encoder was plugged in, no signs of any damaged wiring or wire loom.
I’m not sure what do do at this point. Any suggestions?
Any critters chewing on your wiring harnesses? When we see multiple codes across several different areas it is usually an electrical problem. First culprit is usually a tired, worn out battery, or a battery that pasts tests but has a bad cell. Next up are the battery cables and grounds. Then critters chewing on the wires. I find it odd that the pump and module went out at the same and then the controller for the transfer case went too. Could she have been struck by lightning?
I got a code for the tc switch recently, cleared it and it kept on working just fine. Replaced it anyway because I didn't want an issue when might really need it.
sounds like a shorted wire or circuit somewhere, you might try poking around for any service bulletins noting those codes and hopefully pointing to a potential area to look/inspect.
M
Mighty Hd
Florida
So I got the fuel pump control module replaced and programmed today, those codes are now clear.
Verified that the 4wd system works. No CEL/service 4wd light illuminated; for $15, I swapped the selector switch and also did a relearn on the encoder motor. All bi-directional tests operate as they should.
Checked the ground again by the driver door body mount and it’s clean as a whistle. No wires are pinched, no rubbing underneath or within the dash.
If it were the TCCM, the 4wd system would not function / or be unable to bidirectionally communicate with the module.
Grrrr
M
Mighty Hd
Florida
Oh. Battery is a year old. I have the hall monitor unplugged and has been for several years now. That stopped my annual battery replacement issue.
Cables are clean and tight.
Stored in the garage, no critters or bugs.
M
Mighty Hd
Florida
When I replaced the fuel pump module assembly, there were very fine metal flakes clogging the sock and all around the bottom of the white module cup that contains the pump.
The dealer advised today that most likely the pump motor was the culprit. As a result the pu p probably pulled too many amps for too long, thus burning up the.pump control module.
It’s running like a scalded dog now…just need to get the other codes addressed.
It looks to me like the 4x4 codes indicate that the system is seeing high voltage on the encoder circuit coming out of the TCCM/ATCM. Have you measured the voltage (typically 5v, but I'm not specifically familiar with your system) that the TCCM provides to the switch and encoder circuit? A Tech 2 scanner would show you what the supplied voltage is, as well as the voltages that the various modes send back by the encoder motor.
The circuit voltage can be measured at the dash mode switch harness, for starters; then at the T/C connector. One cause could be a 12v wire rubbing on the reference voltage circuit. Also disconnect, inspect, and clean the encoder circuit connectors if that hasn't been done yet.
EDIT: don't necessarily assume that the TCCM is good; further diagnostics should be done to confirm. You'll likely need a wiring diagram from AllDataDIY or similar, with troubleshooting steps for the specific codes.
M
Mighty Hd
Florida
I checked every connector, every ground that I could possibly find..and cleaned them well. Same codes are being stored in the TCCM.
I also attempted to connect the ground under the driver side door directly to the battery and I'm still getting the same codes. Also cleaned all the electrical connections on the transfer case using compressed air and reassembled. No signs of corrosion on any of the connectors.
Checked most all of the underhood wiring harness and no indications of frayed wiring; removed the lower portion of the dashboard on teh driver side and confirmed the TCCM wires were not pinched or frayed.
The 4wd actuator switch lights all illuminate and the 4wd cycles through all modes fine (2wd, auto, 4hi, 4lo and neutral.
Using a foxwell bi-directional, I can manually engage the front axle actuator, cycle the encoder motor, etc.
I'm really scratching my head here as the system functions fine..yet it's showing codes in the TCCM.
I'm half tempted to say F-it as the system does work....
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Related but not sure it has much value.
After you're done scratching your head, and when you get to the point of using a voltmeter (or a Tech 2, which should show this in the T/C data), check the reference circuit voltage at the switch, both connected to and disconnected from the switch. The TCCM doesn't send 12v to the reference circuit. If it does, it's defective.
M
Mighty Hd
Florida
I was able to get the following data from my scan tool, I didn't think to look at the live data.
2wd:
(Automatic Transfer Case) ATC Range Switch: 1.97v
ATC Range Select Switch Reference: 5.00v
Range Actuator Position Sensor Voltage: 7.60v
Range Actuator Direction Signal: 4.15v
Range Actuator Diagnostic Signal: 4.15v
ATC Range Position Sensor Volts: ON
ATC Range Position Sensor: 37 deg
ATC Range Position Sensor: 2.85v
Control Module Voltage Signal: 12.20v
4hi:
ATC Range Select Switch: 3.00v
Range Actuator Command: 0%
Range Actuator Current -0.20 amps
Range Actuator Position Sensor: 37deg
ATC RAnge position Sensor: 37 deg
ATC Range position sensor: 3.00v
M
Mighty Hd
Florida
There is no CEL or service 4wd indicator on the dash. Whenever I go into the transfer case control module to read the codes, they show up.
I can clear them, and the same ones immediately return.
M
Mighty Hd
Florida
The codes are still present in the transfer case module.
I’m now getting “Engine Power Reduced” with a large number of codes on the ECU and now the Fuel Pump Module again.
P0053
P0054
P0060
P0116
P0128
P013a
P013b
P013c
P013d
P015A
P015c
P0420
P0430
P0442
P0446
P0451
P0454
P0455
P0646
P0496
P0506
P0507
P1400
P3400
P3401
P3425
P3441
P3449
P0011
P0030
P0036
P0050
P0056
P0101
P0102
P0103
P0106
P0121
P0131
P0132
P0133
P0134
P0135
P0137
P0138
P013E
P013F
P0140
P0141
P014A
P014B
P0151
P0152
P0153
P0154
P0155
P0157
P0158
P0160
Vehicle starts up and runs, once I clear the codes it will drive ok until the next ignition cycle.
Clearing the codes, they will immediately return upon the next ignition cycle.
Not a clue, although I suspect that there is one or more bad grounds or rotted cables (positive and/or negative). Have you pulled the ECU connectors off and checked them for cleanliness?
M
Mighty Hd
Florida
I did that yesterday, no indications of corrosion.
I have yanked, removed, cleaned and retightened the grounds at
Battery to engine block
Ground strap from the firewall to engine
Ground wire from battery to behind the front bumper
Ground wire under driver side door on the body mount
Ground wire on the LT rest body mount. Two at this location
I’m getting engine reduced power consistently after a 5-7 mile drive to work and let the vehicle cold soak in the parking lot for 8.5 hrs.
Starts up fine, no MIL, get the reduced power message. Runs fine as well.
Get back home and it’s loaded with codes again. Clear term and it’s fine until,the next restart and cold soak.
Key on, engine off. I can audibly hear The throttle body actuating. It’s a bit clankly sounding.
Wires at TB and MAF checked, And both throughly cleaned.
M
Mighty Hd
Florida
What is a hall monitor?
A bad cell in a battery can pass tests and cause all kinds of havoc with the electrical
I was having trouble with bad batteries every 6 to 12 months. Once I disconnected the whole monitor on the negative battery cable that problem on the way and has been fine for years.
Battery basically ran down to around 11.5 to 12 V and the alternator would begin charging again. The vehicle never ran long enough to fully recover from when the battery ran down so therefore the battery was always in a low state of charge five out of the seven days a week due to my short drive to work.
this is right out of the GM "manual":
The electrical power management (EPM) system is designed to monitor and control the charging system and send diagnostic messages to alert the driver of possible problems with the battery and generator. This EPM system primarily utilizes existing on-board computer capability to maximize the effectiveness of the generator, to manage the load, improve battery state-of-charge and life, and minimize the system's impact on fuel economy. The EPM system performs 3 functions:
• It monitors the battery voltage and estimates the battery condition.
• It takes corrective actions by boosting idle speeds, and adjusting the regulated voltage.
• It performs diagnostics and driver notification.
The battery condition is estimated during ignition-off and during ignition-on. During ignition-off the state-of-charge (SOC) of the battery is determined by measuring the open-circuit voltage. The SOC is a function of the acid concentration and the internal resistance of the battery, and is estimated by reading the battery open circuit voltage when the battery has been at rest for several hours.
The SOC can be used as a diagnostic tool to tell the customer or the dealer the condition of the battery. Throughout ignition-on, the algorithm continuously estimates SOC based on adjusted net amp hours, battery capacity, initial SOC, and temperature.
While running, the battery degree of discharge is primarily determined by a battery current sensor, which is integrated to obtain net amp hours.
In addition, the EPM function is designed to perform regulated voltage control (RVC) to improve battery SOC, battery life, and fuel economy. This is accomplished by using knowledge of the battery SOC and temperature to set the charging voltage to an optimum battery voltage level for recharging without detriment to battery life.
The Charging System Description and Operation is divided into 3 sections. The first section describes the charging system components and their integration into the EPM. The second section describes charging system operation. The third section describes the instrument panel cluster (IPC) operation of the charge indicator, driver information center (DIC) messages, and voltmeter operation.
Charging System Components
Generator
The generator is a serviceable component. If there is a diagnosed failure of the generator it must be replaced as an assembly. The engine drive belt drives the generator. When the rotor is spun it induces an alternating current (AC) into the stator windings. The AC voltage is then sent through a series of diodes for rectification. The rectified voltage has been converted into a direct current (DC) for use by the vehicles electrical system to maintain electrical loads and the battery charge. The voltage regulator integral to the generator controls the output of the generator. It is not serviceable. The voltage regulator controls the amount of current provided to the rotor. If the generator has field control circuit failure, the generator defaults to an output voltage of 13.8 volts.
Body Control Module (BCM)
The body control module (BCM) is a GMLAN device. It communicates with the engine control module (ECM) and the instrument panel cluster (IPC) for electrical power management (EPM) operation. The BCM determines the output of the generator and sends the information to the ECM for control of the generator field control circuit. It monitors the generator field duty cycle signal circuit information sent from the ECM for control of the generator. It monitors a battery current sensor, the battery positive voltage circuit, and estimated battery temperature to determine battery state of charge (SOC). The BCM sends idle boost requests to the ECM.
Battery Current Sensor
The battery current sensor is a serviceable component that is connected to the negative battery cable at the battery. The battery current sensor is a 3-wire hall effect current sensor. The battery current sensor monitors the battery current. It directly inputs to the BCM. It creates a 5-volt pulse width modulation (PWM) signal of 128 Hz with a duty cycle of 0-100 percent. Normal duty cycle is between 5-95 percent. Between 0-5 percent and 95-100 percent are for diagnostic purposes.
Engine Control Module (ECM)
The ECM directly controls the generator field control circuit input to the generator. The ECM receives control decisions based on messages from the BCM. It monitors the generators generator field duty cycle signal circuit and sends the information to the BCM.
Instrument Panel Cluster (IPC)
The IPC provides a means of customer notification in case of a failure and a voltmeter. There are 2 means of notification, a charge indicator and a driver information center (DIC) message of SERVICE BATTERY CHARGING SYSTEM.
Charging System Operation
The purpose of the charging system is to maintain the battery charge and vehicle loads. There are 6 modes of operation and they include:
• Battery Sulfation Mode
• Charge Mode
• Fuel Economy Mode
• Headlamp Mode
• Start Up Mode
• Voltage Reduction Mode
The engine control module (ECM) controls the generator through the generator turn on signal. It monitors the generator performance though the generator field duty cycle signal circuit. The signal is a 5-volt pulse width modulation (PWM) signal of 128 Hz with a duty cycle of 0-100 percent. Normal duty cycle is between 5-95 percent. Between 0-5 percent and 95-100 percent are for diagnostic purposes. The following table shows the commanded duty cycle and output voltage of the generator:
Commanded Duty Cycle
Generator Output Voltage
10%
11 V
20%
11.56 V
30%
12.12 V
40%
12.68 V
50%
13.25 V
60%
13.81 V
70%
14.37 V
80%
14.94 V
90%
15.5 V
The generator provides a feedback signal of the generator voltage output through the generator field duty cycle signal circuit to the ECM. This information is sent to the body control module (BCM). The signal is a 5-volt PWM signal of 128 Hz with a duty cycle of 0-100 percent. Normal duty cycle is between 5-99 percent. Between 0-5 percent and 100 percent are for diagnostic purposes.
The BCM will enter this mode when the interpreted generator output voltage is less than 13.2 volts for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2-3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.
Charge Mode
The BCM will enter Charge Mode when ever one of the following conditions are met.
• The wipers are ON for more than 3 seconds.
• GMLAN (Climate Control Voltage Boost Mode Request) is true, as sensed by the HVAC control head. High speed cooling fan, rear defogger and HVAC high speed blower operation can cause the BCM to enter the Charge Mode.
• The estimated battery temperature is less than 0°C (32°F).
• Battery State of Charge is less than 80 percent.
• Vehicle Speed is greater than 145 kph (90 mph)
• Current Sensor Fault Exists
• System Voltage was determined to be below 12.56 volts
• Tow/Haul Mode is enabled
When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9-15.5 volts, depending on the battery state of charge and estimated battery temperature.
Fuel Economy Mode
The BCM will enter Fuel Economy Mode when the ambient air temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 amps and greater than -8 amps, and the battery state of charge (SOC) is greater than or equal to 80 percent. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5-13.1 volts. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.
Headlamp Mode
The BCM will enter Headlamp Mode when ever the headlamps are ON (high or low beams). Voltage will be regulated between 13.9-14.5 volts
Start Up Mode
When the engine is started the BCM sets a targeted generator output voltage of 14.3 volts for 30 seconds.
The BCM will enter Voltage Reduction Mode when the calculated battery temperature is above 0°C (32°F). The calculated battery current is less than 1 amp and greater than -7 amps, and the generator field duty cycle is less than 99 percent. Its targeted generator output voltage is 13 volts. The BCM will exit this mode once the criteria are met for Charge Mode.
Instrument Panel Cluster (IPC) Operation
Charge Indicator Operation
The instrument panel cluster (IPC) illuminates the charge indicator and displays a warning message in the driver information center (DIC) when the one or more of the following occurs:
• The engine control module (ECM) detects that the generator output is less than 11 volts or greater than 16 volts. The IPC receives a GMLAN message from the ECM requesting illumination.
• The BCM determines that the system voltage is less than 11 volts or greater than 16 volts.
• The IPC receives a GMLAN message from the body control module (BCM) indicating there is a system voltage range concern.
• The IPC performs the displays test at the start of each ignition cycle. The indicator illuminates for approximately 3 seconds.
• The ignition is ON, with the engine OFF.
Battery Voltage Gauge Operation
The IPC displays the system voltage as received from the BCM over the GMLAN serial data circuit. If there is no communication with the BCM then the gauge will indicate minimum.
Utilities and light duty full size pickups are equipped with a new regulated voltage control (RVC) system. This system turns off the alternator when it is not required in order to improve fuel economy. The generator will turn back on when additional voltage is required. This will cause the voltmeter to fluctuate between 12 and 14 volts as opposed to non-regulated systems which usually maintain a more consistent reading of 14 volts. This fluctuation with the RVC system is normal system operation and NO repairs should be attempted.
The BCM and the ECM will send a GMLAN message to the DIC for the SERVICE BATTERY CHARGING SYSTEM message to be displayed. It is commanded ON when a charging system DTC is a current DTC. The message is turned OFF when the conditions for clearing the DTC have been met.
JamesinAbilene
