Awesome job.SOLVED!
Adjust front diff backlash 2013 Suburban
Great work George! Now I know where to take my truck for this! hahahawww.tahoeyukonforum.com
Awesome job.SOLVED!
What’s wrong now?Finally got the hoe back in the garage.
Motivation building to tear back into the engine...
took a week off at the end of this month, probably will start then.
My 2001 5.3l has 3.73 and it's surprisingly quick. That's with the 4l60 trans, so don't know how those ratios compare to the 6l80I thinks it’s for the top end. Off line both are slow, but get into the power band over 25, and 100 is here before you know it.
It ought to but they run 1410 u-joints. I would see if their control arms are the same or in the same position.Anyone know if the K2XX rear suspension/axles fit our gmt900s?
Curious if the 12 bolt 9.76" would swap in.
(Although I'm not going to do that since I already have a 14bolt in hand for a couple hundred bucks whereas those new 12 Bolts are around $2K)
But it did get me thinking...Still semi floating, 33 spline
1/⁴” larger ring gear, less cover bolts
Nice. Is this something you had or were you able to recreate it from a website?
I actually have the hardcopy of it. Along with the manual and the police vehicle supplement.Nice. Is this something you had or were you able to recreate it from a website?
What’s wrong now?
So main bearings or was it just thrust bearings? I thought you replaced them and were all set. Sorry but my email notifications keep quitting and I end up falling behind in my followed threads. Stupid TYF web service.oh same thing, i just gave up for a little while.
took a nice long break and went on vacation, 3 Oktober fests, took the wife out to eat lots, etc.
Now that it's winter and other projects out of the way, I'm ready to dig in and fix this ***** once and for all.
Oh and I also have my fuel tank empty this time.
So i'll probably toss a fuel pump in there, assuming the mood hits me.
yeah i did just the thrust bearing and it burned it out again.
since then i also bypassed the trans oil coolers after attempting to get a before and after pressure reading.
Was never able to confirm for sure due to a short oil pressure gauge hose, but i did notice i'm getting more transmission/engine breaking with the coolers bypassed.
I also was able to reverse flush some metal from the transmission cooler when i disconnected it, so i'm feeling pretty good that it's the issue...
I left it there, decided i was done and needed to get outside and do things for the remaining part of the summer.
getting back to it now, plan is to pull the pan and see if the crank looks ok, or if i see more damage than last time.
Plan is to roll a new (probably the original used 5.3 thrust i have) thrust bearing in to place to see if it burns it out.
If it looks good, then i'll roll a fresh bearing into place and run it.
If the engine gets pulled, i'm installing a transmission pressure gauge (probably a perm install like i did to my vette).
Transmission pump will probably get replaced for good measure.
and all new bearings, and possibly new crank.
I'm hoping i don't need to go that far.
Should I bother with the genuine GM sensors or just go for the Denso units on RA? I recall reading that Denso made them for GM anyway.Got a P015B code and CEL this morning. Tech2 called out B1S1. Exhaust got stinky too. I did a graph of the sensors and they seem to sweep ok. Fuel trims are ok with LTFT -3 on both banks. I will take a look at that sensor since I was just working in that area the other day. Might be time for a pair of new sensors at 88K...
Ordered the Denso sensors along with a sensor wrench thingy. Never had one and have always got the job done but would like to have it.That's what I heard. I have Denso. No complaints.
...a sensor wrench thingy. Never had one and have always got the job done but would like to have it.
Thats what I always used but I thought this might be nice.You mean an adjustable hammer? I have them in metric and SAE. They fit the sensors perfectly.
Be sure to have one for each side of the engine.You mean an adjustable hammer? I have them in metric and SAE. They fit the sensors perfectly.
This!You mean an adjustable hammer? I have them in metric and SAE. They fit the sensors perfectly.
