Anyone know if the K2XX rear suspension/axles fit our gmt900s?
Curious if the 12 bolt 9.76" would swap in.
(Although I'm not going to do that since I already have a 14bolt in hand for a couple hundred bucks whereas those new 12 Bolts are around $2K)
But it did get me thinking...Still semi floating, 33 spline
1/⁴” larger ring gear, less cover bolts
It ought to but they run 1410 u-joints. I would see if their control arms are the same or in the same position.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Got a P015B code and CEL this morning. Tech2 called out B1S1. Exhaust got stinky too. I did a graph of the sensors and they seem to sweep ok. Fuel trims are ok with LTFT -3 on both banks. I will take a look at that sensor since I was just working in that area the other day. Might be time for a pair of new sensors at 88K...
My 2001 5.3l has 3.73 and it's surprisingly quick. That's with the 4l60 trans, so don't know how those ratios compare to the 6l80
Just Fishing
Can't fix stupid
Utah
What’s wrong now?
oh same thing, i just gave up for a little while.
took a nice long break and went on vacation, 3 Oktober fests, took the wife out to eat lots, etc.
Now that it's winter and other projects out of the way, I'm ready to dig in and fix this ***** once and for all.
Oh and I also have my fuel tank empty this time.
So i'll probably toss a fuel pump in there, assuming the mood hits me.
So main bearings or was it just thrust bearings? I thought you replaced them and were all set. Sorry but my email notifications keep quitting and I end up falling behind in my followed threads. Stupid TYF web service.
Just Fishing
Can't fix stupid
Utah
yeah i did just the thrust bearing and it burned it out again.
since then i also bypassed the trans oil coolers after attempting to get a before and after pressure reading.
Was never able to confirm for sure due to a short oil pressure gauge hose, but i did notice i'm getting more transmission/engine breaking with the coolers bypassed.
I also was able to reverse flush some metal from the transmission cooler when i disconnected it, so i'm feeling pretty good that it's the issue...
I left it there, decided i was done and needed to get outside and do things for the remaining part of the summer.
getting back to it now, plan is to pull the pan and see if the crank looks ok, or if i see more damage than last time.
Plan is to roll a new (probably the original used 5.3 thrust i have) thrust bearing in to place to see if it burns it out.
If it looks good, then i'll roll a fresh bearing into place and run it.
If the engine gets pulled, i'm installing a transmission pressure gauge (probably a perm install like i did to my vette).
Transmission pump will probably get replaced for good measure.
and all new bearings, and possibly new crank.
I'm hoping i don't need to go that far.
:yuno:
:yuno:
Did you measure the crank snout depth when you installed the pulley?
George B
¯\_(ツ)_/¯
Should I bother with the genuine GM sensors or just go for the Denso units on RA? I recall reading that Denso made them for GM anyway.
George B
¯\_(ツ)_/¯
George B
¯\_(ツ)_/¯
vsaravia
