The right axle flange is pushed out of the housing. ???
I think you might be on to something here....
well, if it doesn't stay in then maybe..... I have heard of them just popping loose before
Got the wiring done so the C-shaped led acts as DRL only and also will come on with the park lamps. Just waiting on parts to convert the old drl bulb to a park/turn signal. Then need to decide to move forward with the led projector retrofit.
DRL
DRL + park lamps
Hopefully.Worth a try. Hopefully the clip is still okay.
The verdict is in. Looks like the cir-clip ate through the washer in the case. Almost seems like a part is missing. Looking up the assembly now. Need parts. View attachment 357247View attachment 357251View attachment 357252View attachment 357253View attachment 357254
But Mobil one is dirt cheap there in 5 qt jugs!!!!!I’ll never go to Wal Mart, can’t stand that store. So many unsettling people in their stores in my part of the woods plus they’re always super crowded.
Looks like it got hot from the snap ring riding on the washer/spacerThe verdict is in. Looks like the cir-clip ate through the washer in the case. Almost seems like a part is missing. Looking up the assembly now. Need parts. View attachment 357247View attachment 357251View attachment 357252View attachment 357253View attachment 357254
No, not a lot.Looks like it got hot from the snap ring riding on the washer/spacer
did the magnet have much metal on it?
One thing I noticed was that the CV axle pulled back away from the stub shaft when I unbolted it like the boots were pulling on it. Thats a Cardone axle from RockAuto. That pull, although not very strong is bearing on that snap-ring and washer.Looks like it got hot from the snap ring riding on the washer/spacer
But… the front suspension is at full drop right now. I bet it doesn’t pull when it’s sitting on the ground.One thing I noticed was that the CV axle pulled back away from the stub shaft when I unbolted it like the boots were pulling on it. Thats a Cardone axle from RockAuto. That pull, although not very strong is bearing on that snap-ring and washer.
I've only seen the 5qt jugsBut Mobil one is dirt cheap there in 4 qt jugs!!!!!
did you test the actuator?No, not a lot.
That’s what I meant. TypoI've only seen the 5qt jugs
