unless you are snowed in you are good to go, lolThats what I figure it is. Shop floor is all wet now and the Mrs needs me today.
I has taken a-lot for me to learn that things like this are not critical. I used to get all balled up and would go to fixit mode. Now I can let it ride.unless you are snowed in you are good to go, lol
Thats what drove the discovery.Now watch you get a bunch of snow in the next couple days!
junkyard probably has one, just unplug the harness, grab a wrench and break it loose, then it just spins out, you might loose a couple ounces of fluid on the ground.Thats what drove the discovery.
Found out my four wheel drive is inoperative. Front axle wont engage. Transfer case shifts into all modes and ranges.
When in 4HI and with one front wheel off the ground I can turn it. Drive shaft doesn’t turn so I suspect the actuator or shift fork mechanism. Checked with the tech2 and the truck believes all is well with no codes anywhere and everything seems to respond correctly.
then you can either put the harness back on, hit the 4wd button and see if it works or not, or just apply 12v to the pins, sometimes they might barley move or move real slow. a good working one should move quick.
More clues…Make sure the grounds that are on the frame, behind the driver front tire and below where the driver's foot would be are clean and good. One of those, I think, may be for the front actuator. You can also unscrew the actuator and let it hang down, and push your 4HI button to see if it extends. If it takes more than a second or so, or doesn't extend at all, you may need to test the circuit or replace the actuator.
EDIT: If you haven't yet, use the Tech 2 to command the 4x4 modes. Make sure that what's commanded, and indicated on the dash switch, is what the Tech 2 shows is actual. As an example, mine had an encoder motor that would light the switch in 4HI (as selected) but actual mode was AUTO.
HMM, well that's not right and would explain the fluid puddle, looks like it's been like that for a while has it been worked on by anyone? have you checked to see if it is full? i'm gonna guess it's not, if you remove the fill plug/bolt the fluid should be level with the holeThe right axle flange is pushed out of the housing. ???
This is new. I was just under it less than a month ago doing the oil change. I inspected everything at that time. The diff is full and I check it regularly. The truck hasn’t leaked a drop since I have owned it. The front axle was out for service 40k ago by a dealer. I replaced that cv over a year ago. Thats all I know.HMM, well that's not right and would explain the fluid puddle, looks like it's been like that for a while has it been worked on by anyone? have you checked to see if it is full? i'm gonna guess it's not, if you remove the fill plug/bolt the fluid should be level with the hole
Yeah, I was just looking at this. It looks like there is a cir-clip that let go. I can try to knock it back but I might try getting that half off.I am not sure if you can unbolt the axle and then smack that back in with a deadblow or not or if you have to pull that housing off and put back in that way. all the rebuild videos show it just going back in easy with the housing when reassembled
edit I was looking at the wrong side
on this video he shows at 25min just hitting it with a dead blow
Based on this it looks like I will need to pull that side of the diff off. I wouldn’t trust that I git that clip right otherwise.I am not sure if you can unbolt the axle and then smack that back in with a deadblow or not or if you have to pull that housing off and put back in that way. all the rebuild videos show it just going back in easy with the housing when reassembled
on this video he shows at 25min just hitting the one side with a dead blow
im confused on which part it is at 27 min he shows the other side just getting pushed on
I agree but am not sure if the clip is possibly broken.Looks like the culprit right here, I bet you can just dead blow it back in and be fine
well, if it doesn't stay in then maybe..... I have heard of them just popping loose beforeI agree but am not sure if the clip is possibly broken.
