George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Picked these up and went to install them. I noticed they are only rated for 200 hrs. Um, no… not when i have to take the front bumper off to get to them. At $60.00 they are going back. I am not sure what I want to do here. I would really like to try some Morimoto 2stroke 3.0 but there is not much room behind these lights. I am afraid they wont clear the core support. Plus $200 is a bit steep to me. Going to do more research.
KeylessOption Keyless Entry Remote Control Car Key Fob Replacement for Cadillac Escalade ESV, EXT https://www.amazon.com/dp/B010O0L7E...abc_NSPYVBM1RKVS2495WQ4J?_encoding=UTF8&psc=1
Will this work on my 08 Yukon Denali??
probably not unless your module happens to be the same number, there are other options you can order a fob case to make it look like the caddy remote or get a updated looking fob from boost auto and then transfer that to a AJT case those are pretty nice
I went with all black but they make all different colors and you can mix-n-match
alpha_omega
Michigan
I towed my car on a uhaul car trailer. Not the dolly. Used regular mirrors just fine in my NBS. Have yet to tow with this but I don’t see myself getting different mirrors or anything to do so. I was able to see everything needed with the mirrors the truck came with.
A flatbed or car hauler wouldn’t be an issue, it’s a longer enclosed trailer that make using “tow mirrors” a much nicer addition - especially when backing up a longer enclosed trailer with extra head height.
alpha_omega
Michigan
As much as i like those, they're no longer on my list. They're pretty expensive and i can get the output i want for less with an HID retrofit. These are sealed units, so if the bulb goes out you have to replace the whole unit is my guess
Hmm? Does “work on a replacement” mean - “Sure thing! Just send us your old ones, then pay full retail and shipping for a new set.”?
Bill 1960
Testing the Limits
Rotating/cleaning the wheels/tires this morning. Found this at the passenger side UCA. Does it appear to be the OE ball joint or boot going bad? No play that I can replicate. No tear that I can see in the boot either. These appear to be the factory originals. With 150k on the clock, it may be time to replace the control arms anyway to freshen up the bushings.
Passenger
Driver
I’d just clean it up and observe. No play, no reason to replace. That stain could have come from the road. Tires pick up anything on the pavement and sling it around.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
There’s a lot of stuff that I can’t find in my local stores lately. I went to Ace Hardware yesterday to buy an old work electrical box so I can add a cable outlet in my MBR and they were out of almost all electrical boxes so I thought, no biggie I’ll go to Home Depot where they have a huge inventory. I’m standing there looking and I see zero old work boxes- no singles, doubles, triples, deep, shallow…the entire area where they were supposed to be was empty. I pulled out my phone and ordered a set of 3 (couldn’t buy a single) from Amazon. It will be here today. They’re the only retailer that seems to be keeping everything in stock. As I was walking out of HD, I went by the construction adhesive section and it was empty as well, and there were several people on phones calling their bosses to tell them. I see Amazon has it in stock.
Amazon is on the driver's seat right now sad to say. They certainly planned ahead.
Yessir. Between their own logistics and their massive amount of new warehouse space built in the last few years they saw this coming. They even bought their own fleet of 747’s and are continuing to grow all arms of the supply chain. They’re way out in front of so many things it’s ridiculous.
Same here!
I haven't shopped for an old work box in years. It was always one of those standard items that you just go and get. Not these days. I went up and down the aisle thoroughly convinced that I was just overlooking them.
Same here!
I know,I actually had to ask an employee where the old work stuff is and he said “ well it’s supposed to be this whole area here if we had any but it looks like we don’t”.
I can see the manager at the plant saying “well we’re at half production so let’s just stop making stuff for remodels. They don’t need extra outlets and stuff, but new construction has to carry on”.
You don't use these kinds of fixtures for old work low voltage?
I did for an interior wall but wanted a full box for this exterior wall so I could keep it from letting so much air through. I plan on adding spray foam to the inside of it to seal it up. My house has enough cold air drafts as it is. Might be a hair brained idea but what the hell. :mad:
08z71bgm
Long Island, NY
I know exactly what you mean!
St. Louis
Walmart
George B
¯\_(ツ)_/¯
Found out my four wheel drive is inoperative. Front axle wont engage. Transfer case shifts into all modes and ranges.
When in 4HI and with one front wheel off the ground I can turn it. Drive shaft doesn’t turn so I suspect the actuator or shift fork mechanism. Checked with the tech2 and the truck believes all is well with no codes anywhere and everything seems to respond correctly.
probably the front actuator, you can unscrew it and test it visibly, it's possible if it hasn't been used that it is just lazy/stuck, not sure what you could do to "fix" it but it's certainly easy to replace.
George B
¯\_(ツ)_/¯
Thats what I figure it is. Shop floor is all wet now and the Mrs needs me today.
johnsonwillie199
