I am not hearing the ticking at all...Is this ticking normal it only does it when the engine is up to temp it does not do it on cold start is this normal
The only way it has worked for me is to post the clip to YouTube then insert a link here.Ive tried to add a video and keeps telling me the extension is not available idk what that means dose anyone know how i can post a video thank you
Is it odd that it only does it when the engine is up to temp is there any oil additive that would quite it down a bitIMO, that does sound like a lifter tick noise. But I have also seen here and heard here about driving 1000's of miles with no problems.
Its on 5w 30 mobile 1 synthetic with a fram filterI have never been a fan of oil additives. What oil and filter do you use now?
Its on premium gas its due for a oil change ill have to go with ac delco on the filterI am ok with the oil but have never been ok with Fram. IMO use AC Delco or Wix Premium. Several members have said they use Fram with no problems and that is their choice but I just have my preferences. Again, flex fuel or gas?
So i believe i found what is the broken exhaust bolts that might be related to the ticking im talking about I've read that this might be the causeI am ok with the oil but have never been ok with Fram. IMO use AC Delco or Wix Premium. Several members have said they use Fram with no problems and that is their choice but I just have my preferences. Again, flex fuel or gas?
It is a very common issue, I agree you likely have found the source of the ticking noise.So i believe i found what is the broken exhaust bolts that might be related to the ticking im talking about I've read that this might be the cause
Is there any easy way of fixing this issue instead of trying to drill out the boltsIt is a very common issue, I agree you likely have found the source of the ticking noise.
