Rocket Man's 2008 Bagged CC Silverado Build AKA "THE MACHINE"
I jacked it up and see it’s a heim joint that broke. Luckily I was pretty much home and not driving down the road.
I left the spacer off and drilled a hole through the stud. Then stuck a small bolt and nut through so it can’t pop off and backed it into the driveway. I’m not familiar with these joints and not sure if I can buy that bolt alone or what. Whatever I do it will have to be stronger because this is bullsh*t.
I jacked it up and see it’s a grim joint that broke. Luckily I was pretty much home and not driving down the road.
Damn! I can't even imagine if it would've broke while you were driving on the highway!
Well that was an easy fix. It was just a bolt that broke. That side had a 5/8 x 5 1/2” and the other side was a 6” with different markings so I’m not sure if the one that broke wasn’t a grade 8. I’m thinking it was one they had laying around or a Chinese knockoff. I bought grade 8’s and did both sides. I’ll probably look into getting some stronger ones. I’m not a metallurgist so I’m not sure what can be gleaned from the break, if any.
Also while I’m fixing this I notice a socket is missing from my new shallow set. Guess which one is missing? :mad:
No sh*t. I can’t believe I was able to walk across the street, roll my floor jack to my truck and grab the tools to make a temp fix so I could back it in the driveway. And the fact that the front was aired way up so I could turn tight to back in, so that tire didn’t tear up my fender like it would if it was at ride height. That would have been like violently turning the steering wheel while the tire was against the fender. I have done that once while parking and the result was new fenders.
McMaster only had 5/8-11 coarse thread. I found an online seller, Allensfasteners.com, that had 5/8- 18 fine thread grade 9’s. I could only find grade 8 nylock nuts though so I’m guessing those will have to do.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
What about Grainger or MSC?
randeez
south florida
id look into the crushed head locking nuts instead of nyloks for something that critical or double nut it
i say that but ive def done some sketchy **** lol
Would that be these @randeez ? They’re called Flexloc on this site.
randeez
south florida
yea something like that or
AdrienR
