89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Looks like Mars in there. That’s a disgrace.
BG1988
the elite ceramic pads last me generally about a year and half, they would last a normal person many years, I'm a race car driver apparently.....
NRS Brakes Galvanized Pads :D Made in Canada
eh?
The brakes are the most important part of your SUV
I would not install trust with china garbage esp when it comes to the most important part f the suv
eh?
it appears that autozone pads are likely made by Bosch
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
RooTBeeRthe1st
Manifold-cat flange studs had enough, threads magically disappeared. Thankfully O'Reilly's had dorman manifolds in stock.
That lil guy in the back could be why bank 1 is always leaner...
Grabbed it with vice grips and it just sheared off right inside the head... So it'll stay there until I pull the engine.
Finally got my wide band sensor in, I just need to wire up the module at some point.
FedEx finally dropped off my other lower control arm and expansion tank hose.
Through my resonator on the tail pipe(looks horrible) just tacked in place at the moment...didn't change drone as much as I thought, bit I'll leave it for the week to be sure.
Wonder if it would do more before the muffler.
alpha_omega
Michigan
Don’t worry, you’re not the only one with this issue. Bummer you couldn’t get it out of there with a set of vice grips. That’s the only thing that I’ve ever found to work besides welding a nut/bolt in place. 13633BCC-139A-4B4C-8866-1F5B1EC3CD94.jpeg785CD152-FFCE-4BBB-849D-8EEF3C8183AD.jpeg
NjA4207
