pwtr02ss
Tennessee
aaand i have bearing material in the filter again.
lots of it.
this was a short drive, any mild pedal action was quickly pulled back.
so one last ditch effort to bypass the cooler, then i think the engine is coming out. :banghead:
Dammit man. I hate to hear that. I'm hoping the best for you. I haven't even checked the oil since I did my refresh. **** it. It's not making any noise other than lifter noise in mid range rpm. Hopefully it's good
St. Louis
Night pic of brake light
I got those recently for my wife's car.
I learned with every vehicle when i need to buy pads, it's autozone and i buy the best they have.
since i keep cars until they die, it's a good investment. ;)
they didn't have the rears instock, so i got the next line down for those.
we were leaving for a long road trip, so it was more urgent than anything else.
I wasn't sold on the whole "copper free" thing, to me it seems like more about environment vs performance.
But, I absolutely love those pads over the stock ones she had.
and the front wheels aren't showing any real signs of brake dust.
wife likes to drag her brakes going down hills and can warp rotors... :jester:
The rear wheels are pretty brake dusty.
I wish i could have taken more time and either found a store with them in stock, or ordered them in.
but...
we were pretty much leaving for the trip the next day, and i was focused on getting the brake pedal firm after flushing the fluid and having a spongy pedal afterwards.
Oh and tech 2 abs bleed, worth every penny for that tool. :beer:
So far the trick seems to be, normal flush until fluid is clear.
then break out the tech2 for an ABS bleed with the same vac tool connected.
and the Tahoe is going to get the same pads once it's time. :headbang:
I put the elite ceramic pads on both the Silverado and the Yukon, they work well, I couldn't say if they are any better than the old stock ceramics but they are certainly not worse. I haven't rear ended anyone "yet" so that's good. I tried the carbon fiber ones briefly but they are noisy as hell and make a ton of dust. they sound like your wheeling around on a 1940's rusty tricycle.
Oldewing
Central Ohio
Day 3 of our trip to Destin Fla from Ohio. Stopped in Tenn. at wife's sisters first day. Now in Brimingham Al. running to Destin this morning. Towing our RV along with our 3 dogs in the back of the truck. RV is a 27 foot ultralight, at 5K loaded. Gas seems to hang at 9 MPG, would like more, but then who wouldn't....
All in all, nice trip. I put new tires on both before I left, that helps my mind lots.
Just Fishing
Can't fix stupid
Utah
Watch out for that little stock filter, not much capacity.
can plug up and bypass pretty quickly.
and that weird lifter noise i get in mid range rpm and light throttle is back.
I hadn't noticed it at first.
then i had it come back on my way home.
I'm starting to wonder if it's endplay related now.
I posted a link in iamdub's build thread for the oil filter cutting tool i have.
good idea to cut that baby open every so often
I have 4 filters on hand right now (and a missing box of another 4 somewhere else :jester: )
So far me switching to the larger capacity filter and checking it so often has prevented me from getting metal through the engine.
And during engine break-in, everything was going great at first.
I'm now wondering if maybe my new converter tossed something into the cooler lines.
I have a few feet of trans cooler hose, my plan is to bypass the radiator one.
I just need to get a line gauge on the transmission, my plan is to get a before and after reading.
I also regret reinstalling the ac belt.
I have figured out how to get that baby on pretty easily using the install tool that came with the OEM belt.
but getting it off in one piece is a pita. :confused:
St. Louis
Install a tensioner pulley and belt from an earlier model. Easy peasy install and removal. Or pick up a Lisle install/removal tool
Yesterday-
Borrowed these wheels to take the declads off to have the tires replaced. These were on his Tahoe when he bought it. We call them the "Uggos":
They're 18". He had to trim about an inch off his lower ball joint stud, which included shaving some off the nut. I guess this is due to the Belltech spindles? Mine BARELY contacted the rim. I shaved the thickness of the death disc (1.14mm or 3/64") for adequate clearance:
Speaking of neighbor's Tahoe, he finally got it back from the body shop. I don't have any current pics, but it looks just the same as it did before the wreck, just with new paint and no badges or side molding. Pre-wreck:
RooTBeeRthe1st
Ordered a new shifter cable bushing.
Full tank of 91, ethanol sensor is reading zero even though it's like e7-8.
And now the fuel trims are off from when I had recalibrated the MAF when it was running e85 because I was being dumb.
So I'll recalibrate it now while I'm running this and switch back to ethanol afterwards.
pwtr02ss
Tennessee
Yesterday-
That tahoe looks great. Very familiar...I miss you having those wheels.
It does and I miss 'em , too. I sold him the almost new tires I had for those wheels about a week before he went on a trip and wrecked. He didn't install them and hydroplaned on the worn tires. I can't say the wreck wouldn't have happened, but having almost full tread certainly would've helped. He actually bent the backside hoop of one of the wheels. It was easily repaired and you couldn't tell anything happened. It might've been the same one that I had that hole welded up.
Oh well, it's all done and he's back on the road, sporting my beloved RSTs. It's okay, I'm working on some other wheels that I think I'll like better. They'll have some nearly-new (5K miles, I think?) Pirelli Scorpion Zeros on 'em.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
The Lisle brand tool works great both directions BTW.
ASG-MikeS
