So today I broke the DS motor mount. Being on a trail, we carried on through some very stressful terrain.
Other than the clunking and NVH under high torque, are there any potential damages from continuing operation until I can get into a shop?
Not likely. But you should fix it before your next excursion.
Mine was blown when I bought my Tahoe. I did LOTS of WOT from a dig for quite a while before I finally changed them. I HIGHLY recommend an H3 mount(s). Otherwise, you'll be back in the same boat before the sting of the replacement labor wears off.
RooTBeeRthe1st
I ran mine for 10-15,000mi broken before I figured out what it was when I first got the hoe.
madmanjustice
I got the replacement cables/power supply so i can reinstall my dash cams with the parking monitor. I'll have to figure out how to run the cable for the rear window cam since i cannot fish it straight through the head liner like I did on the PPV.
Also survived the hurricane with only a small (8hr power outage)
Bill 1960
Testing the Limits
Thanks for the reply and @RooTBeeRthe1st also.
Tonight / tomorrow I’ll have to scope out the availability of parts ( H3 preferably) as well as a shop to do the work. This living in RV parks is not great for DIY wrenching.
Mainly I need it to be reliable transportation on road until I get it repaired. No more tempting fate in the wilds until it’s right. I pushed my luck today the stuff I was in, I was worried about the CVs and the G80 spitting out parts. It was rough.
but it ain’t a 2007-2014… poser… ROFLMFAO
Nope but it’s badass! This ain’t no photo chop, just my truck in my front yard on my iPhone…:Nonono:
Bill 1960
Testing the Limits
Quick question: Does the H3 motor mount PN 25847739 fit both 2WD and 4WD Tahoes (2008 4wd model specifically in my case). I ask because the GM parts system shows me two different OEM mounts for 4WD vs RWD.
Interesting factoid, when I search this PN on AC Delco, it gives applications for both the H3 Alpha 08-10 as well as Tahoe 13-14. So did GM give up on the hydraulic mounts and go to the solid ones for the Tahoe late in the GMT900 series?
madmanjustice
Arrg. Discovered the front bumper on my 2014 is not drilled for a license plate. And in Texas a front plate is required. So when i get my plates I get to drill into my nice smooth bumper to install my front plate. :nolol::biggun::killer::Jedi::Rant:
Or not. Front plates have always been required in Oregon. I haven’t run one in years on any of my trucks. Never had a cop even mention it, and I’ve been pulled over many times. You could always hold off and if the police there want to write you up for it, you always have the opportunity to fix it before the court date and the charge is dismissed. At least that’s always the way it’s been here. Unless Texas is super strict in which case I’d move. :yaoface2:
madmanjustice
I have been pulled over years ago for no front plate. I may run without it and take my chances...
RooTBeeRthe1st
RooTBeeRthe1st
They must not have, because I have a 14 and it leaked fluid all over the front end when I bought it.
pwtr02ss
Tennessee
Mine was at work on my phone.
Just used the fancy app options a little bit before posting. Lol originals
:alone:
Fun fact, every digital photo that isn't RAW has some sort of edits...don't sweat it. Even the iPhone picture that @Rocketman posted is "edited" by the software on the phone:anitoof:
Nothing wrong with a little correction here or there:cool:
Sparksalot
Bastrop County, Texas
Here are mine.
The sheriff’s deputies have the same pushbar and plate location
I am just slapping your S C R O T U M … it is badass
TMI
Phlipnstik
