Mildew smell from A/C first couple minutes
shock
The first couple minutes after starting my 19 Tahoe the AC smells like a wet basement. It’s generally garaged so it doesn’t sit in the sun much. The odor clears after a bit.
This is the first summer I’ve owned it.
Is there something I can clean/flush/check for a clog?
There is no wet carpet and it seems to leave a normal wet spot on the pavement. There is no residual smell in the cabin if the AC is off.
Bill 1960
Testing the Limits
There are coil cleaning sprays that can be applied to the evaporator coils. Getting to the coils is the difficult part. You can also rent ozone generators and use one to sterilize the entire interior of the vehicle; that’s what car dealers do. I’ve seen them on Amazon.
tom3
Also don't use the inside air recirculation setting on the AC for any length of time.
Tahoen
Definitely change out your cabin filter
gat0r
DFW
definitely check your cabin filter.
then run by dealer & have them check the status of "afterblow" feature in your ECM. have them enable it , if it is not.
TxVet33
Abilene, TX
with the AC running full blast (frt&back) spray most of a can of Lysol into fresh air intake at the back of the hood.
then replace your cabin air filter.
remember all windows open
houstontaylor
I turn the air conditioning off of recirculating to outside air before shutting the engine off. That lets it air out and dry out.
EvergreenZ71
Firefighter EMT/First Responder
Washington
Ditto on this.
I just had my local dealer do this to both my 2009 Tahoe LTZ & my 2010 Sub 2500. Wife’s 2006 Envoy is getting it next.
JasonW4141
