If your RPO shock codes are 6SH and 7SH then your front struts are 560-707/20955487. The rears are 540-435/25871227.
The rears are not Nivomats, those were used on the GMT800s, unless you crawl under the back and see Nivomats or have G65 RPO code then they are original to the vehicle!
You ought to replace everything, and not just the shocks. Some fellas did the bare minimum and complained about the ride afterwards. The jounce bumpers and spring pads do make a difference and new springs restored my truck's ride height and stance back to original. She was sagging in the rear some.
Here's a parts list and the torque values and socket sizes are on my build page, "Useless Information". The list also includes the other suspension and steering parts and all are GM OE save for the rear coil spring ACDelco Professional number, the originals I could not locate anymore when I was looking for mine.
| Front Suspension and Steering | | | |
| 1 | Nut, Top | 11561435 | 2 |
| 2 | Mount, Shock Absorber | 25869477 | 2 |
| 3 | Coil Spring Seat | 15803177 | 2 |
| 4 | Bumper, Front Strut | 20982216 | 2 |
| 5 | Spring Insulator, Upper | 15840291 | 2 |
| 6 | Front Coil Spring | 25876861 | 2 |
| 7 | Spring Insulator, Lower | 15808594 | 2 |
| 8 | Front Strut | 540-460/20765171 | 2 |
| 9 | Control Arm, Upper, Driver's Side | 25812725 | 1 |
| 10 | Control Arm, Upper, Passenger's Side | 25812726 | 1 |
| 11 | Alignment Cam Guide Pin | 45K26008 | 4 |
| 12 | Alignment Caster/Camber Kit | 45K5012 | 2 |
| 13 | Control Arm, Lower, Driver's Side | 20869201 | 1 |
| 14 | Control Arm, Lower, Passenger's Side | 20869202 | 1 |
| 15 | Suspension Control Arm Bolt, Front, Lower | 15733533 | 2 |
| 16 | Suspension Control Arm Bolt, Front, Lower | 15733534 | 2 |
| 17 | Suspension Control Arm Nut, Front, Lower | 11516133 | 4 |
| 18 | Suspension Control Arm Washer, Front, Lower | 15567836 | 4 |
| 19 | Stabilizer Bar, Shaft Link, Front | 25918049 | 2 |
| 20 | GM OE - Tie Rod, Inner | 19178561 | 2 |
| 21 | GM OE - Rack and Pinion Bellows | 15254057 | 2 |
| 22 | GM Tie Rod, Outer | 15254061 | 2 |
| Rear Suspension | | | |
| 0 | Track Bar (Panhard Rod) | 22863710 | 1 |
| 1 | Rear Coil Spring Insulator - Upper | 15251980 | 2 |
| 2 | Rear Coil Spring Set | 25783733 - 45H2164 | 1 |
| 3 | Rear Coil Spring Insulator - Lower | 15765071 | 2 |
| 4 | Rear Shock Absorber | 540-435/25871227 | 2 |
| 5 | Jounce Bumper, Rear | 15115208 | 2 |
| 6 | Control Arm, Rear, Lower | 22868629 | 2 |
| 7 | Control Arm, Rear, Upper | 15767252 | 2 |
| 8 | Stabilizer Bar End Link, Rear | 15257472 | 2 |
