ZW7 suspension
Joseph Parker
Not sure why this is so difficult. I would like to replace all 4 shock absorbers on my 2014 GMC Yukon XL. Front code 6sh rear ZW7. Premium smooth ride. VIN 1GKS2KE7XER161824. No luck at the local parts store and I've called 3 different dealers and have gotten 3 different sets of part numbers. Through cross referencing and my own deduction... I've come up with front = 22811853 and rear = 22811845. These are gm parts numbers. Can anyone confirm that they are the correct parts? I know the rear shocks are supposed to be self adjusting (nivomat). I just don't have confidence in these parts guys.
If your RPO shock codes are 6SH and 7SH then your front struts are 560-707/20955487. The rears are 540-435/25871227.
The rears are not Nivomats, those were used on the GMT800s, unless you crawl under the back and see Nivomats or have G65 RPO code then they are original to the vehicle!
You ought to replace everything, and not just the shocks. Some fellas did the bare minimum and complained about the ride afterwards. The jounce bumpers and spring pads do make a difference and new springs restored my truck's ride height and stance back to original. She was sagging in the rear some.
Here's a parts list and the torque values and socket sizes are on my build page, "Useless Information". The list also includes the other suspension and steering parts and all are GM OE save for the rear coil spring ACDelco Professional number, the originals I could not locate anymore when I was looking for mine.
Front Suspension and Steering
1Nut, Top115614352
2Mount, Shock Absorber258694772
3Coil Spring Seat158031772
4Bumper, Front Strut209822162
5Spring Insulator, Upper158402912
6Front Coil Spring258768612
7Spring Insulator, Lower158085942
8Front Strut540-460/207651712
9Control Arm, Upper, Driver's Side258127251
10Control Arm, Upper, Passenger's Side258127261
11Alignment Cam Guide Pin45K260084
12Alignment Caster/Camber Kit45K50122
13Control Arm, Lower, Driver's Side208692011
14Control Arm, Lower, Passenger's Side208692021
15Suspension Control Arm Bolt, Front, Lower157335332
16Suspension Control Arm Bolt, Front, Lower157335342
17Suspension Control Arm Nut, Front, Lower115161334
18Suspension Control Arm Washer, Front, Lower155678364
19Stabilizer Bar, Shaft Link, Front259180492
20GM OE - Tie Rod, Inner191785612
21GM OE - Rack and Pinion Bellows152540572
22GM Tie Rod, Outer152540612
Rear Suspension
0Track Bar (Panhard Rod)228637101
1Rear Coil Spring Insulator - Upper152519802
2Rear Coil Spring Set25783733 - 45H21641
3Rear Coil Spring Insulator - Lower157650712
4Rear Shock Absorber540-435/258712272
5Jounce Bumper, Rear151152082
6Control Arm, Rear, Lower228686292
7Control Arm, Rear, Upper157672522
8Stabilizer Bar End Link, Rear152574722
J
Joseph Parker
Only codes that start with g are GU6 AND G80. GU6 = 3.42 gear and the G80 = auto locking rear diff.
What are your Gxx RPO codes inside the glovebox lid?
I don't believe that the NNBS ZW7 uses Nivomats, but someone else on here will know.
J
Joseph Parker
1Nut, Top115614352
Rear Suspension
So now I have a 4th set of numbers. Im curious to know what years the numbers that you gave me might cover. When I look them up the latest vehicle fitment I can find is a 2010. Not saying that the part has changed but maybe the numbers have.
J
Joseph Parker
I
I take that back the numbers for the front do fit the 2014. So does the 22811853. Any 8dea what the difference is?
Brandon2489
According to gmpartsgiant with your VIN plugged in this is the part numbers for the front and rear shocks and struts. You can also use gmpartsdirect and plug in your vin. I have noticed if I use gmpartsdirect and plug vin in it still shows me all options for other rpo codes other than mine. Gmpartsgiant seems to pull parts just for my vin.
Brandon2489
According to gmpartsgiant with you VIN plugged in this is the part numbers for the front and rear shocks and struts.
Notice how this says from 2012 to 2014 also.
I
The numbers I provided after looking them up with your VIN and RPOs are for GM Original Equipment grade parts. The number above also refers to 560-707 so more than likely it is either newer or older than the one I provided earlier. GM often changes part numbers when they switch vendors or make even slight improvements. I wouldn't over-think it, just look at Rock Auto, Amazon and Ebay and see who has the best availability and prices with those 3 part numbers. More than likely, one of those GM part numbers is right next to the ACDelco number on the shock box and sticker. Rock Auto has a 5% off code on this website somewhere.
Unlike generic shocks, GM went to great lengths to fine tune the ride depending on our vehicle's weight because of how its equipped with options. A lesser optioned truck would require different shock valving to offer the same ride as a heavier truck. Mine weighs 5900 pounds on the CAT Scales and have seen a few on here a little heavier and a bunch a bit lighter and all have different valving but all used the same springs.
Are you doing the work yourself or having someone do it?
J
Joseph Parker
Are you doing the work yourself or having someone do it? That's kind of what I figured on the parts number change. Yes I am doing it myself.
J
Joseph Parker
That's what I figured on the parts number change. Yes I am doing the work myself.
Negative no g65 code, but I did remove nivomat shocks from the rear when I bought the truck.
Huh. Well, I reckon that the previous owner may have put them on and they are not original to the truck.
What spring compressor will you be using? Are you going to replace anything else while it is apart? How many miles are on the truck?
J
Joseph Parker
145k on the truck. I was planning on having my local shop put the struts together for me and I would just do the install. I have not yet decided on what else I was going to replace. Wanted to square away the shock absorber numbers first because the first dealer quoted me over $1500 for the parts alone. That took a chunk out of my budget. With the confirmation of the new parts, I have more room ($) to replace more stuff.
The upper and lower ball joints start to go at around this mileage. I had one start going bad much earlier (120K) and then changed them all out at 161K.
We used an OEM Tools MCPhereson Strut Spring Compressor 27036 and had to grind down the locking pins to fit our coils. I should have spent the extra $120 and picked up the clamshell type (K-Tool 70372). The Harbor Freight Ball Joint Separator 99849 also had to be extensively modified and ground down to get it to fit and we still cut off the tips of the ball joint threads to get it on there but it finally worked. I will pick up the proper GM tool for the other trucks as well (J-43631).
J
Joseph Parker
I'll probably replace everything that I can afford. The truck is in pretty good shape and I plan on having it for a while. Also would prefer to not have to do it again. Thanks for the help and all the information
Buford bubba
