ZW7 suspension
Joseph Parker
Not sure why this is so difficult. I would like to replace all 4 shock absorbers on my 2014 GMC Yukon XL. Front code 6sh rear ZW7. Premium smooth ride. VIN 1GKS2KE7XER161824. No luck at the local parts store and I've called 3 different dealers and have gotten 3 different sets of part numbers. Through cross referencing and my own deduction... I've come up with front = 22811853 and rear = 22811845. These are gm parts numbers. Can anyone confirm that they are the correct parts? I know the rear shocks are supposed to be self adjusting (nivomat). I just don't have confidence in these parts guys.
Super Moderator
Elev 5,280
What are your Gxx RPO codes inside the glovebox lid?
I don't believe that the NNBS ZW7 uses Nivomats, but someone else on here will know.
If your RPO shock codes are 6SH and 7SH then your front struts are 560-707/20955487. The rears are 540-435/25871227.
The rears are not Nivomats, those were used on the GMT800s, unless you crawl under the back and see Nivomats or have G65 RPO code then they are original to the vehicle!
You ought to replace everything, and not just the shocks. Some fellas did the bare minimum and complained about the ride afterwards. The jounce bumpers and spring pads do make a difference and new springs restored my truck's ride height and stance back to original. She was sagging in the rear some.
Here's a parts list and the torque values and socket sizes are on my build page, "Useless Information". The list also includes the other suspension and steering parts and all are GM OE save for the rear coil spring ACDelco Professional number, the originals I could not locate anymore when I was looking for mine.
Front Suspension and Steering
1Nut, Top115614352
2Mount, Shock Absorber258694772
3Coil Spring Seat158031772
4Bumper, Front Strut209822162
5Spring Insulator, Upper158402912
6Front Coil Spring258768612
7Spring Insulator, Lower158085942
8Front Strut540-460/207651712
9Control Arm, Upper, Driver's Side258127251
10Control Arm, Upper, Passenger's Side258127261
11Alignment Cam Guide Pin45K260084
12Alignment Caster/Camber Kit45K50122
13Control Arm, Lower, Driver's Side208692011
14Control Arm, Lower, Passenger's Side208692021
15Suspension Control Arm Bolt, Front, Lower157335332
16Suspension Control Arm Bolt, Front, Lower157335342
17Suspension Control Arm Nut, Front, Lower115161334
18Suspension Control Arm Washer, Front, Lower155678364
19Stabilizer Bar, Shaft Link, Front259180492
20GM OE - Tie Rod, Inner191785612
21GM OE - Rack and Pinion Bellows152540572
22GM Tie Rod, Outer152540612
Rear Suspension
0Track Bar (Panhard Rod)228637101
1Rear Coil Spring Insulator - Upper152519802
2Rear Coil Spring Set25783733 - 45H21641
3Rear Coil Spring Insulator - Lower157650712
4Rear Shock Absorber540-435/258712272
5Jounce Bumper, Rear151152082
6Control Arm, Rear, Lower228686292
7Control Arm, Rear, Upper157672522
8Stabilizer Bar End Link, Rear152574722
J
Joseph Parker
Only codes that start with g are GU6 AND G80. GU6 = 3.42 gear and the G80 = auto locking rear diff.
J
Joseph Parker
1Nut, Top115614352
Rear Suspension
So now I have a 4th set of numbers. Im curious to know what years the numbers that you gave me might cover. When I look them up the latest vehicle fitment I can find is a 2010. Not saying that the part has changed but maybe the numbers have.
J
Joseph Parker
I
I take that back the numbers for the front do fit the 2014. So does the 22811853. Any 8dea what the difference is?
carman2197
